Thread: engine cranked over until battery went dead, wouldn't start
Results 1 to 18 of 18
  1. #1 Re: engine cranked over until battery went dead, wouldn't start
    could be the fuel pressure regulator, seen them do the start then stall, then run, first thing in the morning.
    could also be a real dirty throttle body, or fuel pump on its way out. do you hear the pump whine when the key is first turned? not cranked, just turn to run, listen for the whine, its the pump priming the lines. also check the fuel rail for pressure, theres a valve on the rail, uncap it, push the center of it, see if gas shoots out, watch your eyes, it will spray out all over. rag over the valve is a good idea.
  2. #2 Re: engine cranked over until battery went dead, wouldn't start
    SE Level Member twillroth's Avatar
    MN
    Do you hear the pump whine when the key is first turned?
    Yeah, I can hear the pump run for a couple seconds when I turn the ignition on.
    Sent from my iPad using Tapatalk HD
  1. Help battery dead but other issues are concerning
    By 87IROCZOWNER69 in forum General Tech Discussion
    Last Post: 02-06-2012, 09:22 AM
  2. How to get a dead battery out
    By sabarrett in forum General Tech Discussion
    Last Post: 02-19-2011, 07:39 AM
  3. Battery going dead?
    By 90oddz in forum General Tech Discussion
    Last Post: 11-06-2010, 06:54 PM
  4. Battery Dead.. Perhaps from the AMP?
    By Supercharged03GTP in forum Audio, Security & Visual Electronics
    Last Post: 10-02-2009, 11:15 AM
  5. Wouldn't Start
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2008, 09:27 PM
