Thread: Change fan turn on temp
Results 1 to 9 of 9
  1. #1 Change fan turn on temp
    Apr 2013
    Michigan
    Is there any way you can change what temp your fans turn on ?
  2. #2 Re: Change fan turn on temp
    The Boss Iceman6669's Avatar
    Jun 2011
    Tuner
    2011 F-150 Yote powered
  3. #3 Re: Change fan turn on temp
    Apr 2013
    Michigan
    Is that the only way
  4. #4 Re: Change fan turn on temp
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    You COULD wire them to a separate switch so you can turn them on whenever you want. Just can't forget to not turn them on, or leave them on when you leave the car.
  5. #5 Re: Change fan turn on temp
    Feb 2013
    37.295091, -121.930053
    perfect were all done here fokes one word says it all lol YES
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  6. #6 Re: Change fan turn on temp
    Sep 2012
    Clarkston, MI
    Actually I edited my post.
  7. #7 Re: Change fan turn on temp
    You could unhook your coolant temp sensor and it'll run constant.
  8. #8 Re: Change fan turn on temp
    Georgia
    There are other ways to control your fans depending on the year of your car. Caspers Electronics Hi-Speed Fan Switch Kit: 3800 Performance Also the newer Aeroforce scan gauge gives you some control over the fans but I'm not sure if you have to reset the turn on temperature every time you start the car. As I don't have an Aeroforce scan gauge I'm curious to know about having to reset the fan temps every time. If low cost is the most important factor you will probably want to find someone local with a tuner. I using a modified Caspers High Speed fan switch on my car. I bypassed the manual switch with a relay and I have a thermoswitch controlling the relay. I have the manual switch mounted under the hood which is handy for testing the fans.
  9. #9 Re: Change fan turn on temp
    Georgia
    INTENSE-Racing.com: AeroForce Interceptor Scan Gauge Since your gp is an 04 the Caspers fan switch doesn't look like an option for you.
  1. Replaced temp sensor, now temp gauge stays pegged high...
    By DarkLord in forum General Grand Prix Discussion
    Last Post: 04-10-2013, 06:53 AM
  2. How do I change/unplug the wires on my Turn Signal/Multifunction Switch
    By indygrandprix in forum Audio, Security & Visual Electronics
    Last Post: 03-04-2013, 08:32 PM
  3. What temp does the knock sensor turn on at?
    By dsmuts in forum General Grand Prix Discussion
    Last Post: 02-02-2012, 01:43 PM
  4. Coolent temp Goes to regular temp and drops down?
    By Lukesgrandprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-11-2012, 08:11 AM
  5. wont turn over after LIM gasket change
    By 95weclipse in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-02-2011, 03:07 PM
