Thread: Blew tops of pistons
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 81 to 100 of 112
  1. #81 Re: Blew tops of pistons
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    Those afr numbers seem about right to me.
    Gotta mess with the fuel trim though it's adding a lot of fuel. I would check for a vacuum leak.
  2. #82 Re: Blew tops of pistons
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    Alright how exactly do i check it. The tester i got from the auto parts store was weird like outdated. I dont know which hose to connect it to.
  3. #83 Re: Blew tops of pistons
    Dec 2011
    Decatur
    30 cruise its 10.1 ltft 40 cruise its 7 the 16 is idle
  4. #84 Re: Blew tops of pistons
    Sep 2012
    North Carolina
    Quote Originally Posted by 01GrandPrixTURBOGT View Post
    Still a lot. You want to be as close to 0 as possible or at least under 5%.
    You can use a hose and connect to the port on the lower intake beneath the snout for vacuum. Not sure what kind of tester you're talking about though.
  5. #85 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Ok thanks
  6. #86 Re: Blew tops of pistons
    You have a wb to check afr right?
  7. #87 Re: Blew tops of pistons
    Dec 2011
    Decatur
    No not yet I just used my aeroforce intercepter. I want to get one I just got bills to pay.
  8. #88 Re: Blew tops of pistons
    You have a vacuum leak if the LTFT is at -16.4 at idle.
    Get that fixed first.
  9. #89 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Ok ill try clamping all my hoses. I can't believe the intake manifold would have a leak or throttle body I mean its been put together by my old tech teacher that built his own drag car.
  10. #90 Re: Blew tops of pistons
    If you don't have a wb then your afr it's showing you is your commanded afr and not actual.
  11. #91 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Could an exhaust leak like where the front header connects to the crossover cause this? Also to do the fuel pump rewire do I have to drop the tank?
  12. #92 Re: Blew tops of pistons
    Sep 2012
    North Carolina
    Yes and I think yes. Don't remember if your year has the access panel in the trunk.
    With a leak at the manifold the o2 readings are incorrect so the computer won't add the proper amount of fuel. May run rich usually or even lean but either way it's wrong.
  13. #93 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Ok ill have to get some clamps then. Man this is just driving me crazy, I wish I could just find the vacuum leak and be done.
  14. #94 Re: Blew tops of pistons
    Dec 2011
    Decatur
    So i sprayed some carb cleaner around on my hoses and didnt really notice any idle changes, kinda hard with just straight headers. But i got some more numbers. My MAF reads from .69-.70 my MAP reads 32-33 and my O2 reads 180-900 constantly changing. I still need to get clamps for my headers but the part store didnt have any.
  15. #95 Re: Blew tops of pistons
    Sep 2012
    North Carolina
    Look at fuel trims while you spray. Thought I mentioned it before Sorry. If the leak is large You'll hear the idle change but small leaks are much more subtle. Watch your fuel trim before spraying...then while you spray it should start to go negative as its pulling fuel.
    After all of this your engine is going to be so freaking clean LOL.
  16. #96 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Ok ill have a friend watch next time I spray. A clean motor is a good thing lol. But hey do them numbers sound good.
  17. #97 Re: Blew tops of pistons
    Sep 2012
    North Carolina
    Yeah they seem like good numbers to me. All normal idle numbers.
  18. #98 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Thats good. I hope its just a vacuum leak then thats giving me all these problems
  19. #99 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Also ive been hearing a lot about how 01s have more fuel issues. Whys that?
  20. #100 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Ok I think I have a leak on my cyl 3 injector
  1. 1986 Grand Prix w/ factory T Tops
    By GP007 in forum Introductions/Noob Questions
    Last Post: 04-01-2013, 04:27 PM
  2. Blew it up :(
    By shawn3091 in forum General Tech Discussion
    Last Post: 09-13-2011, 11:01 PM
  3. Burnt fluid in a trans with only 3k tops on it???
    By Kejross in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-04-2010, 09:06 PM
  4. blew up Gp AGAIN
    By kaosGP97 in forum The Rant Forum
    Last Post: 08-04-2009, 10:10 PM
  5. air bag blew up!!!
    Last Post: 07-19-2008, 03:35 PM
