Thread: Blew tops of pistons
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 41 to 60 of 112
  1. #41 Re: Blew tops of pistons
    Pictures of holes? Unless you mean the ring landing of the pistons are "chipped" around the 1 o'clock position.
    It has been said that the NA engines don't handle detonation as well as the SC engines. And the SIII doesn't handle it as well as the SII.
    Also been said that KR over time will weaken piston and they can fail without seeing KR.
    If and when you do this again, aim for 1* of KR max even in third gear. Even then, play it safe and aim for zero.
    And don't tune around KR, adjust the pulley size or fix the mechanical issue causing it.
    Should last longer, but there's always that chance.
  2. #42 Re: Blew tops of pistons
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    Yea where the alt bolts in. And I don't have pics yet its still at hos shop. But he said tops of pistons had holes.
  3. #43 Re: Blew tops of pistons
    The valve cover has a hole because someone put the wrong bolt in there.
  4. #44 Re: Blew tops of pistons
    Dec 2011
    Decatur
    That wouldn't cause it to be lean though.
  5. #45 Re: Blew tops of pistons
    Quote Originally Posted by 01GrandPrixTURBOGT View Post
    it lets tons of un metered air into the engine.
  6. #46 Re: Blew tops of pistons
    May 2008
    Schuyler, NE
  7. #47 Re: Blew tops of pistons
    Dec 2011
    Decatur
    well i dont know what else it could be fuel pressure was fine when i tested after the swap
  8. #48 Re: Blew tops of pistons
    Did you test fuel pressure while driving at wot? That's when you'll see the drop off
  9. #49 Re: Blew tops of pistons
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    My next gauge
  10. #50 Re: Blew tops of pistons
    Dec 2011
    Decatur
    No I didn't the gauge I had from oreilys wouldn't reach.
  11. #51 Re: Blew tops of pistons
    Dec 2011
    Decatur
    What gauge do you guys recommend for fuel pressure and afr?
  12. #52 Re: Blew tops of pistons
    Jan 2009
    Tallahassee, FL
    AFR I'd do with an AEM.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  13. #53 Re: Blew tops of pistons
    Dec 2011
    Decatur
    What do you guys think of the fail safe wideband?
  14. #54 Re: Blew tops of pistons
    Sep 2012
    North Carolina
    I just have the UEGO wideband. Don't know what the difference is but mine has outputs you can tap into HP Tuners pro and I log my afr in my scans but I read the gauge to see whats going on while im driving. All I really need. Can peek on the go and read logs when I sit down to change numbers.
  15. #55 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Ok i may try that one out. So what numbers or ranges am I looking for?
  16. #56 Re: Blew tops of pistons
    Sep 2012
    North Carolina
    Idle and cruise will always jump around as the computer switches rich/lean but once you enter PE it should lock in to some degree. 14.3-15.2 idle abd cruise. For another high compression top swap build try 11.0 in boost.
  17. #57 Re: Blew tops of pistons
    Dec 2011
    Decatur
    Ok so the 14.3 is just n/a?
  18. #58 Re: Blew tops of pistons
    Sep 2012
    North Carolina
    No that's cruise and idle afr. Should always be as close to 14.7 as possible but you'll see a little variation. Normal at idle and cruise.
  19. #59 Re: Blew tops of pistons
    Dec 2011
    Decatur
    O yea duh 14.7 is normal haha. So when I get my car back what should I look for first? Fuel pressure and afr while cruising I know can one gauge do this? Also anything else that would cause chipped pistons besides kr.
  20. #60 Re: Blew tops of pistons
    Dec 2011
    Decatur
    po171 is a vacuum leak right? where could i have a leak if the hoses are fine?
  1. 1986 Grand Prix w/ factory T Tops
    By GP007 in forum Introductions/Noob Questions
    Last Post: 04-01-2013, 04:27 PM
  2. Blew it up :(
    By shawn3091 in forum General Tech Discussion
    Last Post: 09-13-2011, 11:01 PM
  3. Burnt fluid in a trans with only 3k tops on it???
    By Kejross in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-04-2010, 09:06 PM
  4. blew up Gp AGAIN
    By kaosGP97 in forum The Rant Forum
    Last Post: 08-04-2009, 10:10 PM
  5. air bag blew up!!!
    Last Post: 07-19-2008, 03:35 PM
