Thread: Ghost Coolant Leak
Results 1 to 11 of 11
  1. #1 Ghost Coolant Leak
    Apr 2013
    Savage, MN
    Ok, well I have a 2007 GP, 3800 Series III engine, 68,000 miles, no performance parts, bone stock grocery getter
    I have a coolant leak that appears to happen after the car shuts off, I cant see the leak itself yet, but it appears to be on the passenger side towards the back.
    First noticed it about 3 weeks ago I went in the garage and I could smell antifreeze faintly. Backed the car out and there was a small oarnge puddle, about 3" in diameter.
    I have been trying to track it down, and am coming to the conclusion that it is probably the plastic elbows or water pump. Unfortunately every thing is so tight back there I cannot get a good visual.
    Any hints, tricks or ideas to track it down?
    I am planning on taking it in on Thursday, would like to hopefully narrow down this issue before then.
  2. #2 Re: Ghost Coolant Leak
    Could be coming from a hose going to and from the heatercore aswell.
    If it leaks after the car is shut off, perhaps go drive it and jack up the front of the car and crawl under it with a light and try to see where the drips are coming from.
    If you didnt live so far away from me, I'd come by and lend a hand.
  3. #3 Re: Ghost Coolant Leak
    Before you start the car in the morning. Take your hand and wipe the areas around the hoses, elbows and water pump. Wherever your hand comes back wet...that's the location right below the leak. No need for vision, if you need a visiual though..grab a mirror.
  4. #4 Re: Ghost Coolant Leak
    Apr 2013
    Savage, MN
    ughhh
    Cant find it, tonight pulled off the coolant reservoir and felt around both elbows,and the heater hoses, it was all dry...
    guess it will wait until Thursday when I get it to the shop, they have hoists and a pressure tool to pump up the pressure in the system to try to see if we can find it. somehow went through almost a quart of antifreze today though.
    so discouraging.
  5. #5 Re: Ghost Coolant Leak
    Jul 2012
    Chicago
    Could it be possible that the rear LIM gasket has failed and is leaking externally onto the lower intake, pooling up and dripping off onto the ground?
    -Carl
  6. #6 Re: Ghost Coolant Leak
    Pennsylvania
    Colonel Mustard, the engine bay, with a pinhole in a coolant elbow?
  7. #7 Re: Ghost Coolant Leak
    Apr 2013
    Savage, MN
    It is at the shop now, they are going to do a more thorough inspection and if we cant find it, they are going to put an ultraviolet dye in the coolant so they can track it with a black light.
    oh well...
  8. #8 Re: Ghost Coolant Leak
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Get rid of the orange stuff. Dexcool + air = acid, which leads to dead gaskets.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  9. #9 Re: Ghost Coolant Leak
    Quote Originally Posted by EJOUIE View Post
    Old dex forumula might have had this issue. However it's not the gasket killer. All the major manufacturers used plastic gaskets like GM and all had issues.
  10. #10 Re: Ghost Coolant Leak
    Apr 2013
    Savage, MN
    Well it has been a long expensive day, but all needed to make my GP ready for another 70,000 miles...
    But on the positive, no more leak, I now have heat, weird noise in the front end is gone and have traction..
    New Items:
    Water Pump
    Coolant Elbows
    Heater Core
    Thermostat
    Front Wheel Bearings
    Brakes
    Tires
    4 wheel alignment
    Have a feeling the rear struts will be next.
    Oh the main culprit of the "gohst leak" was both elbows, they were broke inside the tensioner assy, so if the system has pressure while cooling down it leaked. When hot under pressure no leak. But by the time we were that far in, heck it was only an additional $50 to put in a new lifetime water pump, figured why not...
    Ohh how vehicle maintenance sucks some days.
  11. #11 Re: Ghost Coolant Leak
    Pennsylvania
    Grand Prixs be throwin' 'bows.
  1. ANother coolant leak
    By srspicer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-02-2012, 05:13 PM
  2. Coolant leak
    By Cummins97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-15-2012, 08:06 PM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. coolant leak
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-15-2011, 07:44 PM
  5. My new coolant leak
    By Taz Magister in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2011, 08:31 AM
