Thread: How to test an Air conditioning system
Results 1 to 20 of 21
  1. #1 Re: How to test an Air conditioning system
    St. Louis
    IIRC the pump has to be electric to draw the system down to 30Hg. Once there see if it holds that for 1 hour. If it does, then recharge and call it done. It's what I've always done and no issues so far.
    If you have a leaking seal you will know it since the system will not hold vacuum. New seals should come with a new compressor. You could dye test the system to see if there are any leaks prior to changing the compressor again.
  2. #2 Re: How to test an Air conditioning system
    Apr 2009
    vegas
    It is 65 degrees out and I just checked the pressure or charge level, and it reads at 35psi on a recharge bottle gauge, but the compressor does not engage. I do not know how accurate those gauges are and I am going to go buy a vacuum pump and gauge set. what is the proper psi for proper charge? Is there a way to test the compressor itself?
  3. #3 Re: How to test an Air conditioning system
    Apr 2009
    vegas
    ok sorry but I let the car get to operating temp and the compressor is kicking on. I checked the pressure and it was fluctuating between 28- 32 or so. Does the car have to be running and the ac on, to properly check the charge level? I am just trying to verify that the compressor is definitely bad before I spend the money for a new one. I blows air, just not cold. The compressor does not make any abnormal noises.
  1. Air Conditioning
    By Money Saver in forum General Tech Discussion
    Last Post: 08-31-2011, 07:24 PM
  2. 98 Air Conditioning
    By sofine21 in forum General Tech Discussion
    Last Post: 08-28-2011, 12:03 PM
  3. Cooling system pressure test
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-15-2011, 02:41 PM
  4. air conditioning
    By handirifle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2009, 04:00 AM
  5. Air conditioning
    Last Post: 06-23-2009, 11:33 AM
