Thread: Oil disappearing?
Results 1 to 15 of 15
  1. #1 Oil disappearing?
    Nov 2010
    White Lake, MI
    I have a 2005 Base NA grand prix, 157,000miles.
    130,000 miles had LIM job with gaskets, valve cover gaskets, etc.
    The last two oil changes I have notice a reduction of oil. After 4400miles the DCI came up with low oil, I had to add about a qt back in. This oil change has had 1700miles into it and I check the oil and it was at the 2nd dot on the dip stick out of 4. I added approx 1/2 qt of oil in to get it above the 3rd dot.
    I am not sure where the oil is going. All that I can see that could be a concern is sea-page on the oil pan. There is nothing on the ground.
    Please let me know if these images look like an issue and if its oil pan or main seal issues. How to diagnose my issue?
    http://
    http://
    http://
    http://
    2005 Pontiac Grand Prix, Base, 3800, N/A
  2. #2 Re: Oil disappearing?
    Apr 2012
    Goderich, Ontario
    Those motors do consume a bit of oil which GM considers accepable. A couple of my friends have 04+ with the same problem. Clean all of the oil off your block and pan and then keep an eye on it.
    -Paul Walker
  3. #3 Re: Oil disappearing?
    Nov 2010
    White Lake, MI
    Quote Originally Posted by smoke14 View Post
    It didn't consume really any before.
    Oh forgot to mention that I cleaned up the block with the last oil change and these are the results. So some sea-page.
    Plan to swap the trans eventually, it is on it last leg after a soleniod / shift kit. Then I can get to all the seals.
  4. #4 Re: Oil disappearing?
    Those oil seeps are nothing to worry about, they wont be the cause.
    Try replacing the PCV valve, it just might help.
  5. #5 Re: Oil disappearing?
    Jul 2012
    Chicago
    My car burns about a quart in 5-6,000 miles.
    -Carl
  6. #6 Re: Oil disappearing?
    SWPA
    Yeah, mine loses about a quart over the 5,000 mile interval.
  7. #7 Re: Oil disappearing?
    Apr 2013
    Shelby Twp., MI
    Probably collecting on the intake manifold. Time for new gaskets!
  8. #8 Re: Oil disappearing?
    GM considers 1 quart/oil change to be normal usage.
    When you fill the crankcase, likely you bought the 5 quart jug. It's ok to pour in the entire 5 quarts.
  9. #9 Re: Oil disappearing?
    GTX Level Member SF9777's Avatar
    Jan 2012
    Anaheim, Ca
    Id say change it it every 5k miles, but when we had our 07 GP N/A we had to put in a quart after like 4-5k later. Only sometimes but most of it gets burned a lot in the summer over here, especially if you drive like a maniac like my bro, lol.
    2007 Pontiac Grand Prix Base - Sold
    2007 Chrysler Aspen 4.7 - Current Car/Family SUV
  10. #10 Re: Oil disappearing?
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    You say this started after your LIM gasket job, did you use teflon paste on all your LIM bolts?? If you didn't I'd recommend you pull your UIM back off and check to see if you have puddles of oil where the two bolts are under it. I'd bet the oil is seeping up the threads and pooling there, what's not burning in your motor.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  11. #11 Re: Oil disappearing?
    Nov 2010
    White Lake, MI
    Quote Originally Posted by dbextreme View Post
    I only started to notice this oil disappearing two oil changes ago.
    I changed the LIM gaskets at around 130,000miles and what I used on the LIM bolts was thread lock. I did the whole job word for word from write ups found within this forum. GM aluminum gaskets were put on, with Copper RTV in the four corners before and after. Torqued to spec, in sequential order.
    Not sure I want to pull the UIM just yet. Will monitor, what other signs would show this?
    I had just replaced the PCV when I did the LIM gaskets, could it be bad already?
  12. #12 Re: Oil disappearing?
    Chilliwack BC
    i go through a quart inbetween oil changes. only started happening around 100,000km or so. but hasn't got any worse. It is definately normal i had a discussion with GM customer care on it after the dealer wouldn't do anything on it when i still had warranty
  13. #13 Re: Oil disappearing?
    Nov 2010
    White Lake, MI
    I am wondering if I have bad LIM again?
    I have not checked my oil with a change yet since I am only 1500 miles in to it.
    This is what I found under the cap, moisture. When I put my finger on it and smeared it around it turned milky. Should I do a oil change to check for coolant in the oil?
    http://
    http://
  14. #14 Re: Oil disappearing?
    Not enough there to be worried about. I see you live in MI. aka...where spring is trying to spring..but can't get it's act together. Like us here in CT you are having some nice days then cold days. That crap adds moisture. Start and run the car.. pull the dipstick ....no milk, you are safe.
  15. #15 Re: Oil disappearing?
    If you do short trips, moisture builds up.
  1. Disappearing Trans Fluid
    By tommythecat in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-12-2012, 10:45 AM
  2. Coolant disappearing
    By Newby101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-17-2011, 07:22 AM
  3. Tranny fluid disappearing?
    By jokyfo in forum General Tech Discussion
    Last Post: 10-27-2010, 09:07 AM
  4. disappearing oil
    By Jakegday in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-27-2009, 12:49 PM
  5. disappearing doors
    By crashman in forum Off Topic Discussion
    Last Post: 08-01-2008, 07:13 AM
