Thread: temp gauge discrepency?
Results 1 to 4 of 4
  1. #1 temp gauge discrepency?
    May 2012
    NW lower Mi.
    hi everyone clearing my codes on my gpgt, with an obdII android app with a blue tooth obd connector and notice a 25 degree dicrepency my app. indicated 183-196 degree fluctuation and the dashboard indicator was around 215-225 degrees any one else have this issue?
  2. #2 Re: temp gauge discrepency?
    Yeah the dash gauge in not very accurate.
  3. #3 Re: temp gauge discrepency?
    You have actual numbers on your dash or are you assuming it's linear?
    Most GP's have glorified Ford temp gauges.
    That's right, I said GP's were Fordlike!
  4. #4 Re: temp gauge discrepency?
    May 2012
    NW lower Mi.
    not sure what you mean by linear,I was concerned at the higher than normal temp gauge reading,on the dashboard.the obd android appworks very well for its purpose;I've used it on subaru,ford,isuzu and a gm pickup. 6 bucks for the app and 25 for the bluetooth obd connector.the reading on the app showed a very stable temp avg.183-186 degrees
  1. Temp gauge?
    By 2004GrandPrixGT1 in forum General Tech Discussion
    Last Post: 04-19-2012, 09:41 PM
  2. Temp gauge..
    By Jordin in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-29-2012, 09:48 PM
  3. Temp gauge
    By SnowDrift in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-23-2009, 01:39 AM
