if you split any coolant when the lim came off, make sure you wash down the lifter valley with a quart of oil, then change the oil. and filter.
i had some buggers in the cooling ports as well, just clean that crap out, clean the heads real good where the gaskets go, and the manifold, and slap her back together.
ive yet to see a set of old plastic gaskets that looked good, more proof this job should be done on general principals.
