Thread: Finally!!!
Results 1 to 11 of 11
  1. #1 Finally!!!
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    So I finally got my car running again and its awesome!! Thanks to everyone that helped and put up with all my question. I still have a po171 code that I'm working on but my idle is fine so I don't think its a vacuum leak? Could I have a vacuum leak and rpms be fine? I've been looking at other threads but at work this site is blocked so I can only see one page until I get my laptop fixed. And using my phone takes forever.
  2. #2 Re: Finally!!!
    Pennsylvania, USA
    Try checking your intake for leaks, and especially your throttle body gasket. Possibly even your UIM gasket, lean condition more often than not is just a leak after the MAF sensor, so the engine sucks in air that isn't measured in addition to the normal amount of measured intake air. Too much air for the amount of fuel the car is calculating for.
  3. #3 Re: Finally!!!
    Only way to tell if the RPM's aren't fluxuating is to read the fuel trims...do you have a tuner or a live scanner?
    If so, check for the LTFT's after it is warmed up and at idle.
  4. #4 Re: Finally!!!
    Dec 2011
    Decatur
    I have an aeroforce interceptor. Will that work?
  5. #5 Re: Finally!!!
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Check the EGR tube where it goes in the manifold. They crack right at the bracket.
    Also search on BillBoost37 , he has some helpful how-to's on this.
    1997 Red GTP 182000 miles stock
  6. #6 Re: Finally!!!
    GT Level Member 02GPinNY's Avatar
    Aug 2012
    Port Chester, NY
    My 02' GT is going into the shop tomorrow for the same exact thing. My inspection is up this coming Thursday and I have that po171 code as well with my CEL on. They are going to track it down tomorrow. I don't have time to do it myself and time is running out. I'll let you know what they find tomorrow. My idle is perfect as well and the car runs flawlessly except for the code.
    2002 GT Red, Stock, Work In Progress..........
  7. #7 Re: Finally!!!
    Dec 2011
    Decatur
    I'm gonna try and look at that tube tomorrow and thanks I hope they find it for you.
  8. #8 Re: Finally!!!
    Aug 2012
    Port Chester, NY
    Quote Originally Posted by 01GrandPrixTURBOGT View Post
    I'll post from work if they get it finished tomorrow. You know how troubleshooting goes. Sometimes it's quickly discovered and sometimes not.
  9. #9 Re: Finally!!!
    Dec 2011
    Decatur
    Yea I know what you mean haha
  10. #10 Re: Finally!!!
    Aug 2012
    Port Chester, NY
    Well, I got home from work finally. They had the car the entire day and found that I have a leak at the Upper Intake Gasket, and a small leak at the Brake Booster. Well lucky me! They used some "Smoke Test" that sends smoke through the system and finds any little leaks you may have. Being that the car is in otherwise perfect condition, and that I only paid $1800 bucks for it, it makes sense to me to put the money into it now and get all the gaskets done with the upgraded ones once and for all.
  11. #11 Re: Finally!!!
    Dec 2011
    Decatur
    Ok thanks I may have mine smoked test sometime soon.
  1. finally got one!
    By NR92 in forum Members Rides
    Last Post: 11-08-2011, 11:46 AM
  2. finally
    By boostedcompg in forum Off Topic Discussion
    Last Post: 07-24-2011, 01:56 PM
  3. Finally
    By zildjian102 in forum Off Topic Discussion
    Last Post: 05-20-2011, 12:24 AM
  4. Finally got another GTP
    By Fierogtfreak in forum Introductions/Noob Questions
    Last Post: 02-01-2011, 09:41 PM
  5. finally
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2010, 10:32 PM
