Quote Originally Posted by Chadgervais View Post
With AC on, the fans should be running full time, not cycling.
Question: At idle, if you turn your AC on (as long as its not already O/H) does your gauge start to drop or at least stop rising?
Gauge does stop rising when a/c is on at idle. I will try to bleed the system again tomorrow, and replace the temp sensor again. I dont see why though when I move the wires that run into back of fuse box would cause the fans to turn off even when the a/c is on.
This all started when them dam 90 degree elbows busted.
