Thread: Car cooling fans not working + overheating issues PLZ help.
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #1 Re: Car cooling fans not working + overheating issues PLZ help.
    SE Level Member 99XC600's Avatar
    Apr 2012
    Wilbraham MA
    My fan's don't kick on until I get past 3/4 as well. I would check the relays again. Did you also check all the fuses as well? Maybe you have a bad fuse somewhere.
    Worst case scenario, just drive with the AC on.
    2004 Ivory White Pontiac Grand Prix GT1 - Bone Stock and my 80 mile daily driver.
  2. #2 Re: Car cooling fans not working + overheating issues PLZ help.
    Dec 2020
    Glenavon,Sk,Can.
    Hey. Hope someone is still reading these. Last thread was a while ago. I’m having close to the same trouble as 04GPWHITE but, my issue is that the fans won’t turn on AND the gauge stays low. I have a scanner and it will go up to 215 degrees before I chicken out and command the fans on(which works fine) and cool it down manually. Fans work when commanded. Relays all good. Ect checks out with ohm meter. If the instrument cluster goes bad will that cause issues or would it be the pcm?
  1. Cooling Fans Not Working
    By thewaitinggame in forum General Tech Discussion
    Last Post: 09-02-2011, 10:24 AM
  2. Cooling Fans Not Working
    By 1FASTGTO in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-23-2011, 01:17 PM
  3. cooling fans not running and overheating.
    By gtp40th in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2010, 07:46 PM
  4. 1994 gtp cooling fans not working
    By almighty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 04-01-2010, 09:39 AM
  5. Cooling fans always on?
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 01:29 AM
