Thread: Oil pooling on top of engine after valve cover gasket replacement
Results 1 to 16 of 16
  1. #1 Oil pooling on top of engine after valve cover gasket replacement
    SE Level Member void33's Avatar
    Jan 2013
    Chicago
    Hello,
    *my first post on the forum, I apologize in advance for any mistakes...
    -2000 Grand Prix GT / 3.8L V6
    -I would get smoke every now and then in the summer from my engine (hard to tell exactly where it was coming from but I assume the exhaust manifold) about 6 months ago. I discovered oil pooling in the divots between the valve covers and intake manifold on both the front and rear of the top of the engine so I replaced both valve cover gaskets. I also dried up all the oil and after checking periodically it seemed to have fixed the problem. It is winter now so I haven't noticed the smoke again but I did just notice that these divots are again full of oil. When I say full, I mean roughly .5-1oz of oil per divot.
    Any ideas what my next step should be? Removing the valve covers isn't terrible, but it isn't something I want to do again if there could be another reason why this is happening. Any advice is much appreciated.
  2. #2 Re: Oil pooling on top of engine after valve cover gasket replacement
    Omaha, NE
    Lim Gasket.
  3. #3 Re: Oil pooling on top of engine after valve cover gasket replacement
    you mean pooling up in the lim valley, down by lim bolts? then id say your due for lim gaskets.
  4. #4 Re: Oil pooling on top of engine after valve cover gasket replacement
    Lim gasket
  5. #5 Re: Oil pooling on top of engine after valve cover gasket replacement
    St. Louis
    Did you replace the valve cover bolt grommets when you did the valve cover gaskets?
  6. #6 Re: Oil pooling on top of engine after valve cover gasket replacement
    Jan 2013
    Chicago
    I did replace the valve cover bolt grommets yes.
    Please excuse my ignorance, but how does the labor for replacing the lim gaskets compare to the labor for replacing both valve cover gaskets? Just so I know what I am looking at.
  7. #7 Re: Oil pooling on top of engine after valve cover gasket replacement
    Omaha, NE
    Quite a bit more than valve cover gaskets. You basically have to take the top end of the motor off.
    It's not harder per say, just more time consuming.
  8. #8 Re: Oil pooling on top of engine after valve cover gasket replacement
    the truth is, once you get the fuel rail and harness off. its a pretty easy job.
    costs around 100 bucks in new parts. and about 3 hrs time maybe a bit more. depends on your skill level.
  9. #9 Re: Oil pooling on top of engine after valve cover gasket replacement
    Jul 2012
    Chicago
    My first time doing LIM gaskets took me about 4 hours. I've done 4 LIM gasket replacements since, and I am by no means mechanically inclined. It truly is easy, there's a how-to I can link you if need be.
    -Carl
  10. #10 Re: Oil pooling on top of engine after valve cover gasket replacement
    Jan 2013
    Chicago
    The link would be great thanks nos.
    I am going to try to get that done in the next couple of weeks then, thanks for your help everyone!
  11. #11 Re: Oil pooling on top of engine after valve cover gasket replacement
    heres the link. your not changing the lifters so that part wont apply to you. its really a over view vid, not to much up close shots, but it does give the idea of what your getting into.
  12. #12 Re: Oil pooling on top of engine after valve cover gasket replacement
    as you know taking the coil bracket and alt off are so you can get the valve covers off.
    to just do the lim gaskets, those parts can stay on. remember hes doing new lifters as well in the vid and you need the valve covers off to do that.
  13. #13 Re: Oil pooling on top of engine after valve cover gasket replacement
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    Is it different with a supercharger or no? Vid is a SC 3800...just curious...
  14. #14 Re: Oil pooling on top of engine after valve cover gasket replacement
    I live here. TLSheff's Avatar
    A little bit, not much. Instead of a supercharger you have a plastic intake, Lower Intake Manifold will be different. Most of everything else will be identical. The video will give you a basic idea of what you will be doing.
    I hate to link off to other sites, but this is a solid how-to with pics to help understand everything needed.
    L36 LIM Gasket Replacement (56K) - Grand Prix Net
  15. #15 Re: Oil pooling on top of engine after valve cover gasket replacement
    On a NA motor there are 2 hidden bolts on the inside on the intake always covered in oil. If you can't get your intake off that's why.
  16. #16 Re: Oil pooling on top of engine after valve cover gasket replacement
    Jul 2012
    Chicago
    -Carl
  1. Valve cover gasket replacement question.
    By Russosaur in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2012, 04:38 PM
  2. valve cover gasket replacement
    By Corey Djcoreyt Tindal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-18-2012, 06:21 AM
  3. Valve cover gasket replacement
    By Burgundyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2010, 07:06 AM
  4. Valve Cover Gasket Replacement questions
    By BDEGhost in forum General Tech Discussion
    Last Post: 02-04-2010, 07:26 PM
  5. valve cover gasket
    By BFish in forum 3.4L V6 (LQ1) DOHC
    Last Post: 12-12-2008, 03:51 PM
