Thread: were does this sensor plug in go?
Results 1 to 12 of 12
  1. #1 were does this sensor plug in go?
    Aug 2012
    Nova Scotia
    I have a 2000 pontiac grand prix GT and I couldn't figure out were the P.E.D #5 green color sensor goes right now its sort of hanging by the ignition module since I just did an engine swap. Anyone have any ideas? Thanks
  2. #2 Re: were does this sensor plug in go?
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    It's not the coolant level sensor that plugs into the radiator is it?
  3. #3 Re: were does this sensor plug in go?
    Aug 2012
    Nova Scotia
    I'm not really sure man but is that what it could be?
  4. #4 Re: were does this sensor plug in go?
    Aug 2012
    Nova Scotia
    And I also don't know which plug in goes to the speedo. On the the driveshaft any idea?
  5. #5 Re: were does this sensor plug in go?
    The two wire connector at the diff cover would go to the VSS or speedo. A green plug back there would be the oil pressure sender. Not sure what you are talking about up by the ICM. Can you get a picture.
  6. #6 Re: were does this sensor plug in go?
    Its for the Flux Capacitor.
  7. #7 Re: were does this sensor plug in go?
    Dec 2011
    Decatur
    Well the only one I can think of that's close to the icm is the one that plugs into the radiator. Just look at your radiator and see if the sensor is plugged in. If so its not that one.
  8. #8 Re: were does this sensor plug in go?
    Aug 2012
    Nova Scotia
    Okay ill check
  9. #9 Re: were does this sensor plug in go?
    Aug 2012
    Nova Scotia
    Hey bill Ill get a picture up here soon stay updated with this. Thanks!
  10. #10 Re: were does this sensor plug in go?
    Aug 2012
    Nova Scotia
    Near the bottom of the radiator? Passenger side right?
  11. #11 Re: were does this sensor plug in go?
    Dec 2011
    Decatur
    Yea or if look from front of car on the left between the battery and the fan.
  12. #12 Re: were does this sensor plug in go?
    Aug 2012
    Nova Scotia
    Ok thanks ill look
  1. 2008 Base model plug and plug wire swap
    By MS1227 in forum 04+ Specifics
    Last Post: 12-06-2012, 06:14 PM
  2. stock antenna plug to universal plug?
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 01-08-2012, 10:25 PM
  3. sensor plug help
    By bps02gtp in forum General Tech Discussion
    Last Post: 07-26-2011, 01:43 PM
