Thread: Weird Noise help!!!
Results 1 to 8 of 8
  1. #1 Re: Weird Noise help!!!
    Oklahoma
    yeah, sorry I wasnt clear on that, but as Sabre stated, the wear tabs are part of and built onto the brake pads themselves and the anti-rattle clips should be replaced when the pads are.
    Now, since you stated that one side was worn more than the other, that is a big clue to a brake issue. If the right side is worn more than the other that points to an issue with that caliper.
    That said, without seeing the pad and how they wore, its tough to point to something like the guide pins, caliper piston and so on. HOW the pads wore tells you which part is failing. If they work evenly, but just more than the other side, that would point possibly to a caliper piston issue. If they wore more at the top than the bottom that could point to a guide pin issue.
    Knowing how the pads wore will tell you all you need. But the fact the right side is wearing more than the other, I would look at just rebuilding the whole thing and be done with it. New guide pins, new caliper piston seal, new rattle clips and so on. Rebuild kits for calipers are not expensive at all. And, dont forget about the brake fluid either. Brake fluid, because of its chemical make up, attracts moisture and over time will cause issues.
    Generally speaking its wise to flush the whole brake system about every other year or so.
  2. #2 Re: Weird Noise help!!!
    Oct 2008
    York,PA
    Thanks for all the info guys. I think im going to take the right brake assembly apart sometime soon. I do recall that the anti rattle clip was bent when i replaced the rotors and pads. I bent it back, but maybe the anti rattle clip is constantly being rubbed against to bend it. Where do you suggest buying new ones? i never see them online when searching break parts. Autozone?
  1. weird...
    Last Post: 10-15-2008, 10:56 PM
  2. weird ticking noise coming from turbo
    By lilredss0287 in forum Turbo
    Last Post: 09-05-2008, 08:56 PM
  3. Weird noise. Dropped the car in second.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-04-2008, 12:26 PM
  4. wEIrD tUNe?
    By 1badgp in forum PCM Tuning
    Last Post: 07-10-2008, 10:08 AM
  5. weird noise
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 04:17 PM
