Wear tabs are built in to the pads. When the pad material wear down enough they start to touch the rotor and make the noise. If you replaced the pads you replaced the wear indicators.
I think you're thinking of the anti-rattle clips. They should be replaced on every pad change and can cause squeaking if they're worn out or touching the rotor.
