99 grand prix gt. 3800, engine surges and tac pulsates +/- a couple hundred rpms. Some times it will do it while setting idle and sometimes it will surge while under acceleration. some times when stopped at a red light it will surge and die. It will restart and if you keep a little throttle it will stay running. If it sits for a while, it will start fine and run fine untill the next episode, which may be a while.
I was having the crank position sensor symptoms, and have changed the sensor a few weeks ago for the second time in four years. after the sensor change it ran fine untill a couple days ago, when it started this problem. There are no check engine lights or stored codes. Any sugestions would be greatly appreciated.
