Thread: No crank, just click. Replaced starter, still no crank.. help!!
Results 1 to 20 of 21
  1. #1 Re: No crank, just click. Replaced starter, still no crank.. help!!
    The rubber terminal cover peels back to pull the bolt out
  2. #2 Re: No crank, just click. Replaced starter, still no crank.. help!!
    SE Level Member Steve98GTP's Avatar
    Edmonton
    Cool, sounds good. And i checked, it is the start making the click. Doesn't start in neutral either. I'll throw the new bolt in there hope that makes a difference!!
  3. #3 Re: No crank, just click. Replaced starter, still no crank.. help!!
    Quote Originally Posted by Steve98GTP View Post
    give the starter body a good few shots with a hammer then try to start it up, if you have someone who can turn the key while you beat the starter even better.
    if it cranks after beating it, the starter is bad. it may continue to work but it will be temporary.
  1. No crank. Replaced starter, still no crank. Now what.
    By suctoes in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-13-2013, 01:22 AM
  2. 3 wire crank sensor vs 2 wire with 24x crank trigger
    By greenmachinegtp in forum PCM Tuning
    Last Post: 03-12-2012, 05:45 PM
  3. '98 GT 3.8 won't crank
    By Avant Sport in forum General Tech Discussion
    Last Post: 02-14-2012, 08:40 AM
  4. No crank, no lights, no start? One click thats it !
    By thegipper in forum General Tech Discussion
    Last Post: 11-26-2011, 01:52 AM
