Thread: rough idle, wont move forward, help?
Results 1 to 13 of 13
  1. #1 rough idle, wont move forward, help?
    Aug 2012
    Nova Scotia
    car will start but wojnt stay running for more then 30 seconds and when you try and put it in gear it wont go forward or will shut right off. any ideas on what this could be?
  2. #2 Re: rough idle, wont move forward, help?
    Try unplugging the MAF and giving it another go.
  3. #3 Re: rough idle, wont move forward, help?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Got gas ?
    1997 Red GTP 182000 miles stock
  4. #4 Re: rough idle, wont move forward, help?
    Aug 2012
    Nova Scotia
    yes i have a half tank
    Quote Originally Posted by GTP in RTP View Post
    Got gas ?
    Dec 2010
    DMV
    This ^
    Sounds stupid but mines did that when my damn gauge gave out lol.
  6. #6 Re: rough idle, wont move forward, help?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    dont ask how i know, lol
    SE Level Member Rob97gtp's Avatar
    Jul 2012
    Kansas city
    Is the security lamp flashing? Sounds like a security issue to me
  8. #8 Re: rough idle, wont move forward, help?
    Aug 2012
    Nova Scotia
    no its not flashing, it will stay running for like 20-30 seconds then just shut off.and when i try and put it into drive it wont move forward and just shuts off.
    Dec 2010
    DMV
    Naw I think the security cuts the fuel in like 4 secs iirc.
  10. #10 Re: rough idle, wont move forward, help?
    Aug 2012
    Nova Scotia
    hey my manifold air pressure sensor is broken and i just did a motor swap so im wondering whatever it could be..
    Jul 2012
    Kansas city
    Usually fuel cut off is about 20 to 30 seconds if there is a security issue. Could be crank sensor or ignition module also. Is it setting any codes?
  12. #12 Re: rough idle, wont move forward, help?
    Security related fuel issues are 3-4 seconds. Because the cylinders prime when the key is turned to on, then the injectors do not pulse again.
    Determine what you are missing, spark or fuel.
    Try unplugged the maf and seeing if you can keep the car running longer.
    Pull the IAC and clean it and the bore in the TB.
  13. #13 Re: rough idle, wont move forward, help?
    Aug 2012
    Nova Scotia
    alright, ill try and do that and see what happens.
  1. Key stuck in ignition, shifter wont move with key on...
    By robstout in forum General Tech Discussion
    Last Post: 04-06-2013, 07:45 PM
  2. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  3. NEED HELP ASAP Car wont move
    By gtryda in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-11-2010, 03:38 PM
  4. wont move in any gear
    By Thut420 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2009, 09:05 PM
  5. Almost rough idle
    By DesQ27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-01-2009, 08:31 PM
