Thread: code P0014
Results 1 to 5 of 5
  1. #1 code P0014
    May 2012
    Chicago
    I have a 1999 Grand Prix with a code P0014. Seems to be running fine. What might be causing this code?
    Thanks,
  2. #2 Re: code P0014
    P0014 Camshaft Position - Timing Over-Advanced or System Performance
    Sounds like it might need a new cam sensor. Do some reading and it might give you clues.
  3. #3 code P0014
    May 2012
    Chicago
    I have a code P0014. What might be causing this issue?
  4. #4 Re: code P0014
    forgot about this thread already???? http://www.grandprixforums.net/code-...tml#post943034
  5. #5 Re: code P0014
    Don't multipost threads to get a faster answer.
    Thanks.
    A common issue I've seen is the harness that plugs into the cam/crank sensors/ICM can rub on the harmonic balancer and eat up the wires. Check there...
  1. bad idle maf code driver 6 line 4 code
    By GTPSHAWTY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2012, 05:56 PM
  2. Code Help
    By SCbuick010 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2012, 01:59 PM
  3. '99 Grand Prix GT has code 1810, yet runs great as always, so why the code?
    By McFly1999 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2012, 07:52 AM
  4. Code 172
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2011, 05:28 PM
  5. Need help with a code?
    By FRESCOLIO in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-13-2011, 11:24 AM
