Thread: Coolent leaking out of a fitting on the intake?
Results 1 to 9 of 9
  1. #1 Coolent leaking out of a fitting on the intake?
    Dec 2012
    ks
    I have a 04 gp with a 3800 It has a black 90 degree fitting above the waterpump on the intake on the passenger side it is spraying coolant out of where it meets the intake does anyone know what this is and what it takes to fix? Here are some pictures https://www.icloud.com/photostream/#A1532ODWDIfM7
  2. #2 Re: Coolent leaking out of a fitting on the intake?
  3. #3 Re: Coolent leaking out of a fitting on the intake?
    Dec 2012
    ks
    Hey thanks when I first got the car I was thinking I would be taking the intake off! This looks pretty easy!
  4. #4 Re: Coolent leaking out of a fitting on the intake?
    real easy, new elbows cost around 5 bucks too. or the new metal elbows are out there for 10 to 15, plus shipping if you cant find them locally.
  5. #5 Re: Coolent leaking out of a fitting on the intake?
    Dec 2012
    ks
    I installed new ones last night went smooth and straight forward i bout this car on a impound sale with the understanding it would need new intake gaskets lets just say I stole the thing for what I pd anyway after 12$ in parts and coolant I drove it 40 miles last night and all is well thanks for the help!
  6. #6 Re: Coolent leaking out of a fitting on the intake?
    St. Louis
    Being an 04, you will be replacing the LIM gaskets at some point. Inevitable. Along w/ removing the TB to clean the carbon off of the butterfly valve to solve idle/driveability issues. Just a heads up.
  7. #7 Re: Coolent leaking out of a fitting on the intake?
    Dec 2012
    ks
    It looks to me like someone has do that already i can see new orange gasket material I just wonder if thats why I had the coolant leek is because someone didnt get the fittings in good or the o rings were bad when the reasembled it. I also has had the plastic plenum replaced!
  8. #8 Re: Coolent leaking out of a fitting on the intake?
    you want to loo, between the head and lim at the gasket, if its black, its plastic and needs to be changed. if you see silver your good to to.
    this is new metal gasket, on its side, you can see how thick it is, and its east to see in the car.
    and the orange end caps, well my old ones were orange too. here the whole set
  9. #9 Re: Coolent leaking out of a fitting on the intake?
    Dec 2012
    ks
    Thanks ill take a look at that tonight!
  1. Tranny Fitting Leaking
    By develand in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-26-2011, 02:53 PM
  2. 2002 GP GT 3.8L Small Vacuum Line Connected to Brake Booster Fitting At Upper Intake
    By LoveMyGPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-23-2010, 07:51 PM
  3. leaking coolent please help
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-19-2009, 12:40 PM
  4. hi there.leaking intake.help?
    By pocat in forum General Tech Discussion
    Last Post: 02-18-2009, 09:39 PM
  5. leaking intake manifold
    By chrizzle17 in forum General Tech Discussion
    Last Post: 01-09-2009, 11:30 AM
