Thread: Cooling fan issues. Need help solving problem.
Results 1 to 5 of 5
  1. #1 Cooling fan issues. Need help solving problem.
    Dec 2012
    Fresno
    Recently my 90 degree coolant hoses that run into the lower manifold busted, and caused my car to overheat. I replaced the hoses, and added coolant. Now since this happened my cooling fans wont turn on to cool my engine. I replaced my temperature sensor this morning, and nothing has changed. My next move is to replace the relay. Both fans turn on when I run my a/c but wont turn on to cool the engine. Car temp is fine on highway but rises when driving around the city. Any suggestions? Thanks, Im new to this forum. Marc.
  2. #2 Re: Cooling fan issues. Need help solving problem.
    did you bleed the air out of the system when you re filled it with coolant?
  3. #3 Re: Cooling fan issues. Need help solving problem.
    Dec 2012
    Fresno
    Yes I did. I "Burped" the radiator.
  4. #4 Re: Cooling fan issues. Need help solving problem.
    not the rad, the bleeder valve a top the t stat housing.
    leave the rad cap off, let the car car warm up, wait for the t stat to open, the fans usually come on after the t stat opens.(212 ish) then bleed the valve. open it up a few turns till a steady stream of coolant comes out. shut the screw, top off and cap it.
  5. #5 Re: Cooling fan issues. Need help solving problem.
    Dec 2012
    Fresno
    could air in the coolant system really prevent the fans from turning on?
  1. cooling fan issues
    By nakedredneck in forum General Tech Discussion
    Last Post: 12-10-2012, 08:36 PM
  2. Cooling issues?
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2012, 04:37 PM
  3. Cooling/warming issues
    By StormDragon in forum 3.4L V6 (LQ1) DOHC
    Last Post: 12-29-2011, 06:56 PM
  4. Cooling System Issues
    By CSteen85 in forum General Tech Discussion
    Last Post: 07-28-2010, 06:47 AM
  5. Help me with my cooling issues.
    By Rocket468 in forum General Tech Discussion
    Last Post: 07-24-2010, 07:42 AM
