Thread: UIM swap L36 plastic to L26 alloy questions
Results 1 to 20 of 22
  1. #1 Re: UIM swap L36 plastic to L26 alloy questions
    SE Level Member GT in Kennesaw's Avatar
    Kennesaw, GA
    I'm still waiting for the new UIM, but since there's plenty to do before it arrives, I've started. I took a few photos and will post them. This shows what everything looked like. So far only the intake filter cover and hose removed and a few of the connectors off the throttle body.
  2. #2 Re: UIM swap L36 plastic to L26 alloy questions
    Kennesaw, GA
    From the front of the engine, obvious signs of leaking.
  3. #3 Re: UIM swap L36 plastic to L26 alloy questions
    Kennesaw, GA
    With the UIM off.
    A bit of oil puddled in the LIM
  4. #4 Re: UIM swap L36 plastic to L26 alloy questions
    Kennesaw, GA
    The good news, no water/oil "milk shake".
  5. #5 Re: UIM swap L36 plastic to L26 alloy questions
    Kennesaw, GA
    Here, you can see the evidence of the gasket failure. The space between the EGR pipe and the water port is destroyed.
    Confirmed here. The gasket on the UIM
  6. #6 Re: UIM swap L36 plastic to L26 alloy questions
    Kennesaw, GA
    I question if this is a "distorted" or "warped" plastic UIM failure. It might just be a simple failure of the gasket. Opinions?
  1. Loud clunking sounds like plastic hitting plastic
    By ADrugDealer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-12-2012, 07:50 AM
  2. A Few Swap Questions
    By jaybaum96 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2012, 07:18 PM
  3. Swap questions...
    By motohead in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-29-2009, 11:12 AM
  4. Got some questions about the top swap??
    By biggmman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2009, 06:24 PM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
