Thread: UIM swap L36 plastic to L26 alloy questions
Results 1 to 20 of 22
  1. #1 Re: UIM swap L36 plastic to L26 alloy questions
    Swapping to the L67 TB will require a tune.
    The L26 UIM can use the L36 gasket (I think I trimmed a smidge off of it to get it to clip in)
    You have to tap and seal off the EVAP (I think on the front, right side of the L26 UIM looking at it from the intake opening)
    You also need a GenV to GenIII adapter plate (4 bolt to 3 bolt) and slap that thing on there...I sealed mine with RTV just because.
    I had to extend the vacuum lines a tad as well, and remove the EVAP canister bracket...at this time I also did new fuel injector o-rings, etc.
    It's pretty straight forward.
  2. #2 Re: UIM swap L36 plastic to L26 alloy questions
    SE Level Member GT in Kennesaw's Avatar
    Kennesaw, GA
    Thanks for the information. A couple of questions; did you notice any change in drivability or gas mileage as a result of the mod? What did you do about the coolant passage to the TB? Regarding the EVAP, I've seen 2 methods posted elsewhere, one drilled/tapped a hole in the side of the TB into the existing EVAP port and used a fitting to connect to the UIM EVAP port. The other drilled through the outsise of the UIM into the throat of the UIM, and plugged the EVAP port and the hole drilled on the outside. What method did you use, if either?
  1. Loud clunking sounds like plastic hitting plastic
    By ADrugDealer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-12-2012, 07:50 AM
  2. A Few Swap Questions
    By jaybaum96 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2012, 07:18 PM
  3. Swap questions...
    By motohead in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-29-2009, 11:12 AM
  4. Got some questions about the top swap??
    By biggmman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2009, 06:24 PM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
