Thread: I don't think it's supposed to make this noise...
Results 1 to 13 of 13
  1. #1 I don't think it's supposed to make this noise...
    SE Level Member fromne's Avatar
    Nov 2012
    Omaha, NE
    2012 12 23 23 17 37 - YouTube
    You can skip to the end if you don't want to listen to the engine idle for a bit.
    Also the cruise control cable is holding the throttle open and I can't figure out why
  2. #2 Re: I don't think it's supposed to make this noise...
    iirc the cruise cable hooks in like a brake cable for a hand brake lever on a bike. it also need to be seated and locked in right.
  3. #3 Re: I don't think it's supposed to make this noise...
    Nov 2012
    Omaha, NE
    Issue is that it won't pull far enough to be connected to the tb. it need's to go like another 1/4 in to be positioned right
  4. #4 Re: I don't think it's supposed to make this noise...
    pull the lever back to install the cable.
  5. #5 Re: I don't think it's supposed to make this noise...
    Nov 2012
    Omaha, NE
    i did that but once the cable it installed, it is holding the throttle open
  6. #6 Re: I don't think it's supposed to make this noise...
    take a pic of it.
    sounds silly but maybe the fuse blew?
  7. #7 Re: I don't think it's supposed to make this noise...
    Nov 2012
    Omaha, NE
    2012-12-23234840_zps7b887a8b.jpg photo by fromne01 | Photobucket
    that's as far as it will go and i'll go check the fuse but im not sure why it would blow without the battery being plugged in while we swapped the lim gasket
  8. #8 Re: I don't think it's supposed to make this noise...
    like i said may sound silly but sh it happens.
    your looks a bit different then mine. im sc'ed that may be the difference. it came off it should fit back on.
  9. #9 Re: I don't think it's supposed to make this noise...
    Nov 2012
    Omaha, NE
    Yeah it just seems like the cable sucked itself back into the line and it wont come back out again or something.
  10. #10 Re: I don't think it's supposed to make this noise...
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    lol it is adjustable right at the end of the clip itself see all the notchs u can adjust it to make it fit good doesnt have to make the car go wot
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  11. #11 Re: I don't think it's supposed to make this noise...
    Nov 2012
    Omaha, NE
    Im not sure which clip you're talking about
  12. #12 Re: I don't think it's supposed to make this noise...
    he must be talking about the plastic end on the cable.
  13. #13 Re: I don't think it's supposed to make this noise...
    Nov 2012
    Omaha, NE
    Thanks for the help! It ended up being the pcv valve that was rattling around and I got the cable figured out so she runs great now!
  1. isn't this supposed to be dry??
    By kind153 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-09-2012, 11:49 AM
  2. what is this part and what is it supposed to sit like?
    By aeidian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-01-2010, 03:20 PM
  3. is this how it's supposed to sound?
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2010, 11:03 AM
  4. How hot are l67 engines supposed to get?
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-12-2010, 09:02 PM
  5. Is a pulley supposed to be here?
    By black98gt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2009, 05:42 PM
