Thread: Last Couple Questions on top swap
Results 1 to 20 of 32
  1. #1 Last Couple Questions on top swap
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    Top Swap Photos by 01GrandPrixGT | Photobucket
    Im lost on where these go. Does anyone have pics to show where the go? Please help im almost done with my swap.
  2. #2 Re: Last Couple Questions on top swap
    picture 1: Looks like connection for alt, map, and something else?
    picture 2: You don't need it your sc now.
    picture 3: vacuum connection goes from map sensor to there to fpr to bbv
    picture 4: Where does that end up?
    picture 5: map sensor. The na one is different than the sc one iirc
    on a gt harness that would be egr, air pump then alt.
    on the gt harness the map connector is on the front side of the harness. use an l32 map if you dont want to change the conector. that is granted youre going to use an l67 bin.
  4. #4 Re: Last Couple Questions on top swap
    Dec 2011
    Decatur
    Ok so do i need an adapter for the map and what the supercharged one look like? Can i get a pic of what you mean for 3 im a little confused? And 4 that wac attached to the one that goes to the vacuum that goes to the throttle body.
  5. #5 Re: Last Couple Questions on top swap
    Dec 2011
    Decatur
    Im using a top swap pcm from zzp. Does that mean anything Matt?
  6. #6 Re: Last Couple Questions on top swap
    i dont know what bin they start with.
  8. #8 Re: Last Couple Questions on top swap
    Dec 2011
    Decatur
    ill email and ask them. Also do i need that supercharge bypass solenoid?
    depends on the tune.
  10. #10 Re: Last Couple Questions on top swap
    Dec 2011
    Decatur
    does that mean like it depends on the bin file?
    Yes
  12. #12 Re: Last Couple Questions on top swap
    Dec 2011
    Decatur
    L36 bin. So how do i hook up the map and the rest of the vacuum like the nipple on the fuel rail and the vacuum hose attached to the throttle body vacuum?
    Same as depicted above. Just dont need the bbv solenoid, and use your l36 map.
    Remove it from the manifold then remove the gasket from the nipple.
  14. #14 Re: Last Couple Questions on top swap
    Dec 2011
    Decatur
    What goes on the bottom nipple of the BBV? Thanks man im almost done i may have a few more questions though.
    Nothing. Leave it open to atmosphere
  16. #16 Re: Last Couple Questions on top swap
    Dec 2011
    Decatur
    Where does my map sensor go? The bottom looks like it plugs in to something.
  17. #17 Re: Last Couple Questions on top swap
    theres a vac nipple on the bottom, it routes to the T under the sc snout.
    shows it in post 6.
  18. #18 Re: Last Couple Questions on top swap
    Dec 2011
    Decatur
    http://i1321.photobucket.com/albums/...psa7f54ba9.jpg so stick a vacuum hose on this then run to a T under the snout and then run that line to another T on the FPR then run that one to which nipple on the BBV?http://i1321.photobucket.com/albums/...pse2fc6cc3.jpg
    And where does this go?http://i1321.photobucket.com/albums/...ps5b5d22ff.jpg
    Again im sorry for not understanding this im just worried that im gonna screw something up when im so close to being done.
  19. #19 Re: Last Couple Questions on top swap
    this part, is this off the old n/a engine? im not familiar with it at all.
    and this is the vac routing your looking for. being that your a top swap you may need to take off the n/a lines and just redo it right. vac tubing is cheap. i just re did 1/2 of mine cost 5 bucks with 2 T's
  20. #20 Re: Last Couple Questions on top swap
    Dec 2011
    Decatur
    Yea that what of the N/A on the UIM. I thought that was the map sensor.
  1. Couple questions.
    By PioneerGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-07-2012, 06:27 PM
  2. Couple Questions!
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2010, 08:30 PM
  3. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  4. I have a couple of questions.
    By Enjoijoe in forum General Tech Discussion
    Last Post: 03-12-2009, 07:07 PM
  5. I Have a couple questions.
    By thenervemann in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2008, 08:07 PM
