Thread: Starting Issues
Results 1 to 8 of 8
  1. #1 Starting Issues
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Recently my 03 GT has started stalling after the first second of running. It will start right up, but then die right away. One the second attempt, it has started, knock on wood. The only code is P0420 because a cheapy cat was used a few years back-no big deal with the code-not the problem. I tried cleaning the MAF and that may have made a little worse or no change. Any ideas's, TIA.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  2. #2 Re: Starting Issues
    Clean the IAC.
  3. #3 Re: Starting Issues
    Nov 2009
    A little late
    Is regular carb cleaner safe to use?
  4. #4 Re: Starting Issues
    Jul 2012
    Chicago
    That's what I used. No issues.
    -Carl
  5. #5 Re: Starting Issues
    Nov 2009
    A little late
    Last week, Napa had a flyer for $20 off if you spend $50. I haven't had time to clean my IAC and things may be getting a little worse. I decided I would use the coupon and get a new one. When I was takng out the old one, I stripped out the torx head. My trusty needle nose vise grips got it out. When I bought the new IAC with a few other things, Napa did not have anything close to the right screw length. They did have a hex head bolt with the same threads that was about 3/16" too long, so I washered it up. Should I look a little harder to find the right screw or not worry about it. Thanks.
  6. #6 Re: Starting Issues
    you can cut the bolt down, but its best to find a nut that fits, put it on the bolt, then cut it off, this way when you take the nut off it helps clear the threads up at the end.
    washers should hold.
    you could also, take the old torx bolt, and cut a straight groove in it, so you can use a flat head screw driver to put it back on. i did that to my maf screws.
  7. #7 Re: Starting Issues
    Nov 2009
    A little late
    Attachment 11154
    I hope this works. I am not sure if I want to keep tightening into the aluminum throttle body.
  8. #8 Re: Starting Issues
    Pennsylvania, USA
    Use a lock washer if you stick with those. Like like a washer that's cut and bent up slightly, it will keep it tight.
  1. Starting issues
    By Billyb in forum General Tech Discussion
    Last Post: 12-21-2016, 12:27 AM
  2. starting issues
    By bdm72 in forum Introductions/Noob Questions
    Last Post: 12-10-2012, 12:48 AM
  3. starting issues
    By Sexton in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2012, 12:34 PM
  4. Issues Starting?
    By Eccentric04gt in forum General Grand Prix Discussion
    Last Post: 08-31-2012, 07:25 PM
  5. 04 GP GT2 starting issues
    By jpdubrall84 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 11:58 PM
