Thread: Aluminum oil pan
Results 1 to 11 of 11
  1. #1 Aluminum oil pan
    SE Level Member quiksilvergt's Avatar
    Aug 2008
    Rotterdam NY
    I've heard that some models of the 3800 have an aluminum oil pan like the 98 intrigue, and the 06 and up series 3's I wanted to know if they would fit my 01 grand prix, because I was doing an oil change this weekend and noticed that my oil pan was quite rusted, so I pushed on it a little and the bottom was flexing under my fingers, if im going to replace it I only want to do it once.
  2. #2 Re: Aluminum oil pan
    Oklahoma
    Ive thought about this myself. Didnt the Bonneville have an aluminum pan as well? But Ive 'heard' (take it for what its worth) that in order to use the aluminum pan you needed to have the aluminum cradle as well. But I dont know what truth there is in that.
  3. #3 Re: Aluminum oil pan
    SE Level Member gixer2000's Avatar
    Braintree, ma
    im putting in a l26 block with an aluminum oil pan and i was told the l26 oil pick up tube needed to be used not the l67. Also that the lower engine mount bracket needed to have a 1/4" shaved off
  4. #4 Re: Aluminum oil pan
    Feb 2008
    I would advise against getting a aluminum oil pan. The aluminum ones tend to be brittle compared to the steel ones and can not withstand any kind of hits that may happen while on the road. A steel one will pretty much bend if it gets hit, thus keeping all the oil and running until you can change it if the dent is bad enough it warrants changing. Just my opinion tho, good luck!!
  5. #5 Re: Aluminum oil pan
    Braintree, ma
    i dont think i have ever heard of a wbody having a problem with scraping the oil pan. its almost covered it sub frame and sits up higher than the subframe so i dont see how it could ever hit
  6. #6 Re: Aluminum oil pan
    Feb 2008
    You are right, most oil pans are!! I'm not talking about scraping, you wouldn't believe the crazy things that folks have told me on how they busted their oil pan. I've seen cars come into the shop with broken ones from hitting various things (raccoons, mufflers, pot holes) on the road or the parking lot (parking blocks)
    I even had a car come in on a unrelated issue on a tow, and the tow trucker hit the oil pan with his equipment and cracked the oil pan.
    Personally I'd stick with the steel one!!
  7. #7 Re: Aluminum oil pan
    I live here. UR LOSN's Avatar
    Rockford, IL
    I was told that when using the oil pan, you would have to use the aluminum cradle..... this was what I was told.
    the aluminum pans can take some abuse... I landed my truck on on it when the front end came down too hard.....spider web cracked it. but other than that they do fine.
  8. #8 Re: Aluminum oil pan
    Feb 2008
    Quote Originally Posted by UR LOSN View Post
    Hmmm, interesting, did they say why? Just wondering. I would have thought that the oils pans would be relatively the same.
  9. #9 Re: Aluminum oil pan
    Hoffman/Schaumburg, IL
    Quote Originally Posted by Blown97 View Post
    The aluminum is not as strong at the same thickness as the steel, so it has to be engineered differently also:
    The oil pan in the 06+ is structural, just like the newer GM V8's (I think Ls2 included) The added strength helps stiffen-up the bottom of the block (not that the 3800 really needs it though....)
  10. #10 Re: Aluminum oil pan
    Barksdale AFB, LA
    An iron block needs stiffening.
    2009 Subaru Impreza WRX STI
  11. #11 Re: Aluminum oil pan
    Feb 2008
  1. polished aluminum is a horrible disease
    By turbocharged406sbc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2008, 11:11 AM
  2. polishing aluminum valve covers
    By suprchrgd in forum Visual/Body Modifications
    Last Post: 02-15-2008, 01:09 PM
  3. My new aluminum motor mounts
    Last Post: 01-24-2008, 10:04 PM
