Thread: Coolant bleeding procedures not working. Temp sitting at 160* while moving
Results 1 to 8 of 8
  1. #1 Coolant bleeding procedures not working. Temp sitting at 160* while moving
    Dec 2012
    Lakeland, FL
    A friend of mine and I replaced the lower and upper intake manifold gaskets
    and water pump on my fiance's 01 Grand Prix. It's a NA 3.8 series 2 engine.
    I'm more of a Subaru guy myself and I dont know a whole lot about the
    procedures of GM so I looked up a few things and here's what's up...
    We flushed the engine during the process and decided to fill the block
    with coolant before running it so it would have something in there. We
    removed the thermostat housing and filled it up and put the thermostat
    back on. Then we topped off the radiator and let it warm up While running
    the heater. It got to 210 while idling so I figured it was fine. Then I went to
    take it out for a test drive and while moving the temp dropped to 160 and sat
    there. I figured there was air in the system so I used the small bleed screw on
    the top of the thermostat housing and only coolant came out. It didnt feel like
    much was getting in the upper hose, though. The car takes 2.8 gallons so we
    ended up filling up the coolant reservoir with the last half gallon and it's almost full
    still. We tried driving it, idling it, squeezing the upper hose, removing the radiator
    cap (which air did come out, but now it's only coolant) and if you leave the car
    running with the cap removed it pours out since the radiator is full.
    Also, the fans wont kick on.
    This is the last step in the process. Any chance anyone has any ideas on what
    I can do?
  2. #2 Re: Coolant bleeding procedures not working. Temp sitting at 160* while moving
    SWPA
    Air in the system would cause overheating, not cold symptoms.
  3. #3 Re: Coolant bleeding procedures not working. Temp sitting at 160* while moving
    Nov 2011
    NY
    Lolz... Running cool would tell me it's all working well
    Fans won't kick on cause it's not hot... If running hot and no fans well then that would be an issue.
  4. #4 Re: Coolant bleeding procedures not working. Temp sitting at 160* while moving
    fans dont come on till 212 ish. if you let it idle long enough with the cap off, the fans will come on. then crack the bleeder screw.
    it does sound like its running ok tho, these engines tend to rise and fall temp wise all the time.
  5. #5 Re: Coolant bleeding procedures not working. Temp sitting at 160* while moving
    What thermostat is in it? Maybe it's stuck open
  6. #6 Re: Coolant bleeding procedures not working. Temp sitting at 160* while moving
    SE Level Member Buggsy's Avatar
    Eau Claire, WI
    I'm unsure of the degrees that the gauge represents, but after flushing my engine a year ago, I barely get above 2 marks over a 1/4. In the summer it has a bigger range with driving temps being around 1 or 2 marks below half, but it's cold here now.
  7. #7 Re: Coolant bleeding procedures not working. Temp sitting at 160* while moving
    Nov 2012
    NY
    180nshould be the operating temp no? your thermostat may be slightly stuck open. then again 160 is pretty close
  8. #8 Re: Coolant bleeding procedures not working. Temp sitting at 160* while moving
    Would you please post a picture of where the gauge sits.
  1. Intake temp vs coolant temp.
    By chicagochuck in forum General Tech Discussion
    Last Post: 09-30-2012, 08:44 PM
  2. coolant bleeding procedures?
    By 98regal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2012, 07:07 PM
  3. need help with bleeding coolant system
    By loganrick in forum Engine
    Last Post: 12-26-2011, 01:10 PM
  4. Coolant bleeding
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2011, 06:45 PM
  5. Outside temp not working
    By Fiero in forum General Tech Discussion
    Last Post: 01-24-2011, 10:49 PM
