im ready to re assemble the intake.. and i have packs of rubber band looking seals and not sure what i need them for so if i can get that pointed out and if i need them that help alot..
the small ones are injector O rings, the fat ones go on the bottom, and the smaller ones go on the top of the injector, the other 2 black ones look like coolant elbow O rings, but i could be wrong, the 2 red ones i have no idea.
the side parts of the lim gasket, the rubber part, when you take yours apart use what ever one match's the old one.
On the end seals. This depends on the year of the motor. Search on my name and first design vs second design. Basically if your motor has the pin locations..you use the orange (98+) if not..use the blue.
Scott is right on the rest.
