Thread: Oil filter adapter removal/installation...leaking -_-
Results 1 to 5 of 5
  1. #1 Oil filter adapter removal/installation...leaking -_-
    Ohio
    Removed the engine and trans out the top to swap a new tranny in..
    Dropped everything back in and reinstalled the oil filter adapter with a new gasket. Started the engine up and let it idle for a bit, then it started pissing out of from the adapter and it is coming from the seal between the adapter and the engine.
    I removed it once again, got another gasket, felpro mind you, made sure all the old gasket was off the adapter and got as much off as i could of the engine with a roloc...reinstalled it and it is once again leaking.
    Any ideas at all? Should I double gasket it?
  2. #2 Re: Oil filter adapter removal/installation...leaking -_-
    Grand Rapids, MI
    I had to take that same adapter off when dad and I did the engine swap in the GT. We used a new gasket and didn't have a leak at all. But I'm thinking dad smeared some rtv on the surface around the gasket as a precaution. So maybe you could do that. On both sides of the gasket?
  3. #3 Re: Oil filter adapter removal/installation...leaking -_-
    GrandPrix Junkie
    Mar 2012
    NC
    Already taken care of Brodon...get with the times.
  4. #4 Re: Oil filter adapter removal/installation...leaking -_-
    Grand Rapids, MI
    Quote Originally Posted by hitman92499 View Post
    great minds thing alike
    Ohio
    Lol.. Thanks again Jason. I hope it works... If not.. Well then let's pray my new car gets delivered before I go berserk
  1. Strut removal and installation
    By TheOtherNick in forum How To Write-Ups/Tech Tips
    Last Post: 10-26-2014, 12:08 PM
  2. Zzp tb adapter leaking!
    By 04boostedindyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-20-2011, 03:12 AM
  3. Airbag removal and installation
    By mach158 in forum General Tech Discussion
    Last Post: 06-05-2011, 05:07 PM
  4. Steering Wheel Removal & Installation
    By $03gp/gt$ in forum General Tech Discussion
    Last Post: 12-14-2008, 07:38 PM
