Thread: LS lifter question
Results 1 to 14 of 14
  1. #1 LS lifter question
    Apr 2011
    Elk Rapids, Michigan
    I'm getting the parts together to do a top swap with cam and header upgrades. I have a lifter that takes a short time to pump up and would like to replace them all. I've heard bad things about the Comp Cams lifters so I don't think I'll go that way. I've found some LS motor lifters that say they fit 4.8,5.3,5.7 and 6.0L and the ad said LS7 also. Does anyone know if these will work in a 3800? Thanks for the help.
  2. #2 Re: LS lifter question
    LS7 is the current replacemetn for our lifters
  3. #3 Re: LS lifter question
    Apr 2011
    Thanks Bill, I was hoping you'd be the one to respond. Looks like I'll be picking a set up. Unfortunately they come in a set of 16 so I'll have a few spares.
  4. #4 Re: LS lifter question
    Nope..someone ordered from Texas Speed and I mentioend that..they found a set of 12 for a lower cost than the 16.
  5. #5 Re: LS lifter question
    go in the V6 f body section.
  6. #6 Re: LS lifter question
    Figures it was Matt most likely..lol
  7. #7 Re: LS lifter question
    True story: sold them and threw my stockers back in.
    Even the questionable one.
  8. #8 Re: LS lifter question
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    Idk how much they are off of Texas speed I picked mine off of JEGS or summit (around $120) for a pretty good bargain for 16. I like getting 16 because you can pick and choice your favorite 12.
    97 Bonneville SE Not so much a 97 anymore
  9. #9 Re: LS lifter question
    Apr 2009
    Fort Worth TX
    was wrong with them?
    Should I or should I not get these?
  10. #10 Re: LS lifter question
    Quote Originally Posted by Rico View Post
    Nothing. Bought them for a cam install. Sold cam and lifters.
    One of my stockers has a nice gouge in it, the cam lobes are fine though. Cleaned and reinstalled.
  11. #11 Re: LS lifter question
    Apr 2009
    Fort Worth TX
    Was it that VS you were talking about that you sold?
  12. #12 Re: LS lifter question
    I had actually purchased a GT2. Not ideal for my setup, however it would have sounded great and have been relatively easy on the valvetrain compared to the more aggressive cams, yet not nearly as much overlap as the NIC. Making it easier to tune, better fuel economy, etc.
  13. #13 Re: LS lifter question
    Apr 2011
    I just checked Texas Speed and they have a set of 12 for $98+$13 to ship. Summit has the set of 16 for around $117 + their handling charge, usually $10. I just have to decide if I want the 4 spares for about $15 extra. Thanks for the heads up on Texas Speed Matt! Even if I go with Summit, that will be a good resource. Between you and Bill I might get this thing swapped this year!
  14. #14 Re: LS lifter question
    tennessee
    zzp has sets of 12 for $109+ship
  1. xp cam and 105 lifter question
    By copperpacecar in forum General Tech Discussion
    Last Post: 03-20-2011, 07:13 PM
  2. lifter install?
    By 99prixgt in forum General Tech Discussion
    Last Post: 08-13-2009, 11:35 AM
  3. Bad Lifter?
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2009, 10:03 PM
  4. Colapsed Lifter?
    By jbizach in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-22-2009, 08:48 PM
  5. Lifter Tick
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-21-2008, 06:43 PM
