Here ya go, the actual, been there, done it many times list of what you need to swap:
Rear exhaust manifold
Alternator bracket
Upper manifold and throttle body or get a TB adapter (ZZP) and use the metal UIM with your TB.
Check the number of prongs on the coolant sensor (while it's out) I forget when that changed over.
If your motor came with the black bracket on the front of the oil pan, then use that for a mount instead of the big horseshoe bracket. It's a much nicer pan and setup.
Use your AC bracket
Use your trans diff to engine bracket
Use your fuel rails and injectors.
That's it.
