Thread: 07 GP remote start.....
Results 1 to 3 of 3
  1. #1 07 GP remote start.....
    Nov 2012
    Lebanon, Ohio
    My remote start works every time, however sometimes it will start then it will shut back off seconds afterwards. Not sure if this is common. It only happens every couple days. Its getting cold and I don't want to think I started it, only to come out to a frosted car. lol
  2. #2 Re: 07 GP remote start.....
    GT Level Member GMCustomerService's Avatar
    Michigan
    Spike89,
    Hopefully you'll get some helpful technical insight from other members of the forum (we're limited in what we can provide). If you decide to get this checked into at your servicing dealership, let us know as we're available to work with you through that process.
    Sarah (Assisting Louis), GM Customer Service
    Check out the NEW Owner Center at: My.GM.com
  3. #3 Re: 07 GP remote start.....
    St. Louis
    How many miles on that 07? The throttle bodies like to gunk up and cause strange issues, along w/ the IAC. Might be worth a try just cleaning the MAF and then go from there.
    If you don't use the remote start and actually use the key does it act the same sometimes (shutting off after a few seconds of running)? Did the remote start thing begin when it started getting cold out, or did it do it when it was warm out as well?
  1. remote start
    By gtcoup in forum Off Topic Discussion
    Last Post: 12-23-2010, 08:04 PM
  2. Remote Start???
    By nikkigpgt00 in forum Audio, Security & Visual Electronics
    Last Post: 08-03-2010, 11:09 PM
  3. Remote Start
    By RideMr2 in forum General Tech Discussion
    Last Post: 05-15-2010, 11:09 PM
  4. Remote Start
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-26-2009, 01:00 PM
