Thread: tips/tricks. list for upper/lower intake manifold gasket job..
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 tips/tricks. list for upper/lower intake manifold gasket job..
    Oct 2012
    michigan
    hey guys, new here. ive been searching checking out some threads. i think im pretty much set, but i just want to double check to make sure im not missing anything before i tear it apart.
    im planning on this stuff:
    lower gasket kit. Fel-Pro MS98014T - Intake Manifold Gasket Set | O'Reilly Auto Parts
    UIM: Dorman OE Solutions 615-180 - Intake Manifold | O'Reilly Auto Parts
    im trying to find the "elbow" coolant 90 or whatever everyone keeps talking about changing. any idea on what exactly that part is?
    thanks for any help
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Coolant elbows. I would get the aluminum ones.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  3. #3 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    You can save on the UIM if you plug your LIM. See "How to mod a lim" by me (search on "E A S Y" without spaces and my name.)
    Elbows HP47065 for aluminum ones or plastic 47065 both Dorman part numbers.
  4. #4 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Donating Users triebenbach07's Avatar
    Dec 2010
    long prairie, mn
    02 sedan, top swap
    Ohio
    47065HP.. just so there's no confusion at the parts store
  6. #6 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Yeah..and since you can't get them at the parts store...let's add that bit of confusion in for him? lol
    Ohio
    Who says you can't bill?
  8. #8 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Please .....I would love to have you prove me wrong.
  9. #9 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Ohio
    go into the parts catalog at advance...now remember bill, i do work there.....
    in the parts catalog it will bring up the listing for the aluminum elbows right along with the plastic ones..BUT, it will state that they are unavailable...
    go into the homescreen on our computers where we log in to check somebody out, press F5 for inventory search, type in "47065hp" and it will bring up the price of 14.99 and no local PDQ quantity...
    do a further search for availability and you will find that we can factory direct order them from Dorman for 6 dollars shipping.
    BOOM/
  10. #10 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Dec 2010
    long prairie, mn
    Quote Originally Posted by 99PGPGT View Post
    BOOM/
    Sh*t just got real
    May 2011
    United States
    I got the aluminum elbows frow my local o'reilly.
    Sent from my Droid
  12. #12 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Shush ur mouth!
    Mike...I checked, Samm checked and both were unsuccessful. Well done man.
  13. #13 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Ohio
    sam doesnt know how to work a computer then, and i think you are lying anyways
  14. #14 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    860-745-2364 Tell JP that Bonne Bill suggested you call.
    At $20 a set.. it's kinda not worth it. Could do the plastic ones 5 times
  15. #15 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Ohio
    as i said...shows in our catalog unavailable.
    an inventory search, proves otherwise
    May 2011
    United States
    Shush ur mouth!
    Lol but I'm for serious!
    Sent from my Droid
  17. #17 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    I got the Dorman aluminum elbows at Rock Auto for pretty cheap. Then I saw them in a "HELP" package hanging on that big rack with those Generic HELP parts at Pep Boys. Look at the Dorman website, under brand it says "HELP! - carded".
    In addition you will also want the throttle body gasket FelPro 61093, it's not included in the UIM kit. Also may as well do a temp sensor, AC Delco 213185 and the coolant bypass gasket for the LIM (right under the TB) Victor Reinz C31274. A thermostat and radiator cap would be a good choice too.
    I also did the water pump, the heater hoses and the valve cover gaskets since they are very easy to get to with the LIM and associated parts out of the way. If you haven't done plugs/wires lately this would be a good time for that too (I had just done that prior to the LIM). Also be sure to change the O rings on teh fuel injector when you remove them, new ones come with the Dorman UIM kit,
  18. #18 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    St. Louis
    Get some thread sealer for the LIM bolts so they don't seep later on.
  19. #19 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Georgia
    I'm planning on doing mine. There are some interesting details/issues to consider. I think selecting the most ideal products for the job can be helpful like using the aluminum elbows instead of the plastic ones. You can find differences in opinions on the best product to use on the lim bolts. My research leads me to believe the best choice is to use something that both seals and locks the lim bolts. At this point I am planning on using Loctite 518. On the o-rings for the elbows I am going to use a little Hylomar Universal Blue. I've heard good things about Permatex Aviation Form A Gasket #3 Sealant, thinking about using this on the rubber part of the metal gaskets and on the paper gaskets.
  20. #20 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    I don't suggest using RTV on the elbow o-rings. Clean the holes well and the o-rings will seal. As for the LIM bolts. GM in the later FSM's mentioned blue loctite, however it's not a sealant and those bolts don't typically come loose. A GM tech suggested a pipe sealant with teflon.
  1. Intake Manifold Gasket Parts List
    By Burbman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-03-2012, 03:35 PM
  2. lower intake gasket job list
    By scha0786 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-18-2012, 11:33 PM
  3. how do i know if my lower intake manifold gasket is bad?
    By asite57 in forum General Tech Discussion
    Last Post: 05-08-2012, 07:03 AM
  4. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
