Thread: tips/tricks. list for upper/lower intake manifold gasket job..
Results 21 to 40 of 41
  1. #21 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Aug 2011
    Bucks County Pa
    Quote Originally Posted by crod View Post
    hey guys, new here. ive been searching checking out some threads. i think im pretty much set, but i just want to double check to make sure im not missing anything before i tear it apart.
    im planning on this stuff:
    lower gasket kit. Fel-Pro MS98014T - Intake Manifold Gasket Set | O'Reilly Auto Parts
    UIM: Dorman OE Solutions 615-180 - Intake Manifold | O'Reilly Auto Parts
    im trying to find the "elbow" coolant 90 or whatever everyone keeps talking about changing. any idea on what exactly that part is?
    thanks for any help
    Just a question: Do you really need a UIM when doing the LIM Gasket??
    George
  2. #22 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    yes you do. you cant get the lower intake off with the upper still on. and the upper gasket seems to fail on the N/A engines.
  3. #23 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Or..you plug the coolant ports and run your UIM w/o replacing it.
  4. #24 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Jul 2012
    Chicago
    Running this way for over 2 months now. No problems.
    -Carl
  5. #25 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Aug 2011
    Bucks County Pa
    Bill
    You seem to know alot about these 3.8 engine.
    I understand, per your posts, on plugging the coolant.
    My real question is not the UIM gasket but the actualy UIM why needs replacement unless its been damaged?
    George
  6. #26 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Jul 2012
    Chicago
    If you plug the ports you don't need to replace it. Damaged or not. Unless it's like ridiculously warped or something. The coolant passages that would be leaking if you don't plug the ports can't anymore. They don't have access to coolant flow.
    http://www.grandprixforums.net/97-03...ure-60667.html
    -Carl
  7. #27 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    yeah...^^^ check out that post. It'll show you the biggest problem area
  8. #28 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    Come to my house and we'll bang it out in an afternoon plugged coolant ports the works. Zip 07748
    97 Bonneville SE Not so much a 97 anymore
  9. #29 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Springfield Missouri
    I definitely have to reccomend those aluminum elbos from ZZP I went through 3 of those stupid plastic coolant elbos in the past year. Today I installed my aluminum ones and I am very impressed.
  10. #30 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Don't be impressed until you give them a good test.. BTW, likely you over paid for them. Dorman 47065HP
    On the aluminum elbows everyone is hailing them as the end of all elbow problems. I feel differently, mostly because I don't have problems with the plastic ones. I have had a problem or two, once I realized what caused the problem of the elbow becoming a 45 degree angle instead of a 90, the problem never occured again. The most common issue I find is people putting them in and bolting down the tensioner w/o wiggling the elbows and ensuring they are moving or cleaning out the holes before installing. Then Dorman had a bad batch or a few.
    Now for a history lesson on elbows and why GM had them specificed to be plastic. In 1995-1999 (Bonneville, PA, Riv, LeSabre 1995-1999, GP, Impala, Monte, Regal 1997-1998) the lower elbow was a cast part of the tensioner assembly. GM later changed that, we ask ourselves why. They did it because mechanics were breaking the tiiming cover where the elbow heads into the cover. This is because the elbow had no give and would get crusted in there. By having no give, the timing cover (thin in that area) gave.
    As far as an o-ring leaking. It can sure as heck leak on an aluminum elbow as well as it can leak on a plastic elbow. The o-ring is the same o-ring on either of the two types of elbows.
  11. #31 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Apr 2008
    The 47065HP's are impossible to get at the usual parts stores. I got mine on Amazon, $18.62 shipped and got them in five days.
    Dorman 47065HP HVAC Heater Hose Fittings Coolant Elbows GM : Amazon.com : Automotive
    2001 GT Coupe
  12. #32 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Bill, I've never had any issues with dorman elbows until I installed a set i acquired recently.
    They lasted about 2 months before bending out shape.
    Aluminum elbows are going to corrode and may cause more issues down the road.
  13. #33 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Mar 2012
    Minnesota
    Anybody ever thought to go directly to GM. I have replaced four or,five sets of these, two on the side of the road. First time I bought the dormans. Then ended up doing another set, this time on my car, and used the GM ones. Been good ever since. The GM ones are made of a stronger plastic so they don't crack as easily. I was thinking about fabricating up some steel ones and welding two pieces together. But my GM ones haven't gone at all. Bill boost you said you solved the problem by a 45 instead of am90. What did you mean by that? A 45 degree plastic one?
  14. #34 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Quote Originally Posted by 2004GrandPrixGT1 View Post
    ^^^^^^F all of this ^^^^^ buy metal gaskets, dont even buy the plastic gaskets, thats just dumb.
  15. #35 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Mar 2012
    Minnesota
    Not talking about the plastic lim gaskets, I am talking about the coolant elbows. I totally agree to just by the metal lim gaskets.
  16. #36 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    i was sleepy and miss understood your post lol
  17. #37 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Georgia
    Found an interesting thread on installing intake gaskets and the different sealers you can use. Best gasket sealer for Intake manifold runner ports? - Hot Rod Forum : Hotrodders Bulletin Board
  18. #38 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Just seeing the elbow questions pointed to me.
    2004 what I'm saying is ..when you install the elbow, specifically the upper elbow. If there is pressure on it, when the engine warms up it'll deform to whatever the pressure on it suggests. Therefore my writeup on installing them suggests you wiggle it to ensure it's not being pushed into a 45 degree angle instead of it's 90 degree original shape.
    Chuck.. why would you put anything on a gasket that should be installed dry?
  19. #39 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Nov 2009
    Central Jersey
    The place to put sealer is where the heads meet the block and LIM
  20. #40 Re: tips/tricks. list for upper/lower intake manifold gasket job..
    Georgia
    I agree the general opinion is to install the gaskets dry. I'm not sure that using some high tack or spray tack would cause any problems. The most common problem areas seem to be with the elbows leaking and the bolts leaking from what I've read. Some say the teflon paste can melt. Some say use aviation cement on the bolts. Some say you can use pipe dope. I'd like to a good job the first time so I don't have to re do it.
  1. Intake Manifold Gasket Parts List
    By Burbman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-03-2012, 03:35 PM
  2. lower intake gasket job list
    By scha0786 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-18-2012, 11:33 PM
  3. how do i know if my lower intake manifold gasket is bad?
    By asite57 in forum General Tech Discussion
    Last Post: 05-08-2012, 07:03 AM
  4. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
