Thread: Temperature Problems
Results 1 to 20 of 77
  1. #1 Re: Temperature Problems
    Bastard Reptile's Avatar
    Kansas City, MO
    OK, I found the wires you need to look at, and trace from the PCM to the fans.
    It's going to be pins # 5 & 6 on the BLUE pcm connector. 5 is a dark blue, 6 is a dark green wire respectively. If you pull the PCM connector out, and look into the end of it, they start on the lower left hand side, and go from left to right in numbers. Those two control the temperature low speed fan controls. If those wires are pinched and the circuit is open somewhere, then they will not operate on their own, but will when you turn the AC on.
  2. #2 Re: Temperature Problems
    TDCRacing
    Guest
    Quote Originally Posted by Reptile View Post
    Good man!
  1. ICM Problems??
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-17-2009, 12:53 AM
  2. Before I have problems...
    By Keet04GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-25-2008, 08:22 AM
  3. Many problems/ Please help
    By Vurelis in forum General Tech Discussion
    Last Post: 06-15-2008, 03:45 PM
  4. HUD Problems
    By 03GTPFour in forum General Tech Discussion
    Last Post: 03-09-2008, 10:38 PM
  5. Temperature sender location
    By bat119 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-25-2008, 09:23 AM
