Thread: Why does my 3.8 NA sound supercharged?
Results 1 to 20 of 20
  1. #1 Why does my 3.8 NA sound supercharged?
    GT Level Member Brammer's Avatar
    Feb 2009
    Roanoke, VA
    Recently my car has been getting whiny.... Almost like it's a GTP (I wish). I originally noticed after taking a hard corner the car would get really whiny and then would quit after it was shut off and restarted. I thought it was Power Steering fluid. I never got around to checking it because apparently it's down between the firewall and the engine and it's impossible to tell how much is in there? But now it does it all the time when driving. Here's a quick video with the sound :
    http://s17.beta.photobucket.com/user...9060c.mp4.html
  2. #2 Re: Why does my 3.8 NA sound supercharged?
    It's possible.
    It's called reach down there.
    Check it.
    Probably a bad pump.
  3. #3 Re: Why does my 3.8 NA sound supercharged?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    It is not that hard to check the PS fluid. Just wait for the engine to cool down and reach down there and grab the cap.
    GPONA #1 Cyber Bully
    GT Level Member Utter99's Avatar
    Warsaw indiana
    My transmission pump did that too
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  5. #5 Re: Why does my 3.8 NA sound supercharged?
    Feb 2009
    Roanoke, VA
    I mean I know where the reservoir is, but you can't exactly see the side of it to see where it's at markings wise, I didn't want to add more if it was already at level.
  6. #6 Re: Why does my 3.8 NA sound supercharged?
    Florida
    If your torque converter is thirsty it will sound even more SC'd.
  7. #7 Re: Why does my 3.8 NA sound supercharged?
    Quote Originally Posted by Brammer View Post
    Get at it in the daylight.
    You can see it behind the alternator if you look down.
    It isn't THAT hidden.
  8. #8 Re: Why does my 3.8 NA sound supercharged?
    I think what he is saying,.....is that he believes the side of the pump has a sight glass on it to see the fluid level.
    No go guy.. you unscrew the cap and lift it up. The cap has a dipstick built into it. All you have to do is pull it out and look at it. BTW..that info is in the owners manual.
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    If conering makes it whine, sounds more like transmission. Have you checked the trans level?
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  10. #10 Re: Why does my 3.8 NA sound supercharged?
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    My old trAnny would start whining when it would start to hardshift cause it would max out tranny pressure, either your ps pump or tranny pump
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  11. #11 Re: Why does my 3.8 NA sound supercharged?
    Pennsylvania
    It is the power steering fluid being low, I had the EXACT same thing on my old NA car... corner a little too hard and it gets loud and whiney until you shut the car off and start it up again, and it's magically gone until next time. My dipstick on the ps fluid was dry. Filled it up a little and this problem never happened again.
    Check the fluid, it's not hard, just look behind the alternator. Unscrew the cap, wipe off the dipstick, reinsert and check the level, parked on a level surface preferably with the motor cold. Use a long funnel to fill it... only fill it a little at a time, the reservoir doesnt take much.
    Sport Edition Kv5 18x8
  12. #12 Re: Why does my 3.8 NA sound supercharged?
    Jul 2012
    Chicago
    Same thing happened to me. It would whine in hard corners. Filled up, problem solved.
    -Carl
  13. #13 Re: Why does my 3.8 NA sound supercharged?
    Aug 2012
    MA
    Not sure if this is the right way, but I've been moving the coolant expansion tank out of the way. Then access is not so bad.
    08 Pontiac Grand Prix 3.8L 95k M1 0w40, FRAM ULTRA
  14. #14 Re: Why does my 3.8 NA sound supercharged?
    Feb 2009
    Roanoke, VA
    Just to tie up loose ends for anyone searching for similar issues, it was low on PS fluid and I'm an idiot.
  15. #15 Re: Why does my 3.8 NA sound supercharged?
    Banned
    Oct 2013
    Moorhead, MN
    Lol
  16. #16 Re: Why does my 3.8 NA sound supercharged?
    Aug 2012
    MA
    I just had something similar. Not a whine but a hissing sound from the dashboard under heavy acceleration. Was a clogged heating core. Clogged with Dex Cool
  17. #17 Re: Why does my 3.8 NA sound supercharged?
    We were all new at some point. The talent you do have though...you made us laugh with that one.
  18. #18 Re: Why does my 3.8 NA sound supercharged?
    Banned
    Oct 2013
    Moorhead, MN
    I think I knew the groaning noise was low power steering fluid when I was 12.
  19. #19 Re: Why does my 3.8 NA sound supercharged?
    Dec 2012
    Where 4T65E's were born
    Our dodge p/s pumps groan, but the pump on our impala just whined. They may be a different design or something, idk but they sound very different. To be fair, the dodge p/s pump sounds like a cat slowly getting run over.
    That's funny that he said it sounded supercharged, thats exactly what I though when I heard it lol.
    Sold.
  20. #20 Re: Why does my 3.8 NA sound supercharged?
    Quote Originally Posted by Thompsju View Post
    Yeah..but there's a few clips and things that you are still learning.
  1. Replies: 4
    Last Post: 03-02-2019, 11:28 PM
  2. GXP, GTP, or Supercharged GT?
    By Want a GXP in forum General Grand Prix Discussion
    Last Post: 08-29-2012, 02:18 PM
  3. Grinding sound when making sharp left and awful creak sound when going over bumps
    By rescuetoaster in forum Brakes/Suspension/Chassis
    Last Post: 03-04-2012, 10:06 PM
  4. swap a series 2 supercharged motor for a series 3 supercharged into my 2000 gtp
    By 2000GTPGUY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2012, 04:26 PM
  5. me vs. supercharged cav
    By boosting98 in forum Track Sessions and Kills
    Last Post: 05-03-2008, 12:32 AM
