Thread: redused engine power
Results 1 to 15 of 15
  1. #1 redused engine power
    Illionis
    I have a 2008 pontiac grand prix, and for the last few months i have been experiencing a light that comes on the DLC which says reduced engine power. Right before the light comes on i am on the throttle at a regular pace like in a construction zone following traffic and maintaining speed, but then its like i let off the throttle but i dont then the light comes on then when i try to accelerate its slow and will only go up to 75mph and under full throttle the rpm will sit at just over 3000, when i come to a stop and try to take off it takes almost 20 seconds to engage the throttle to take off and the acceleration is not even there. Also, when i go full throttle at a stop to try and take off faster the throttle will stick and slowly accelerate. Now, i have pulled a few codes if anyone needs them. Thanks in advanced for all the help
  2. #2 Re: redused engine power
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    Quote Originally Posted by zenman400 View Post
    Codes will help, please post
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  3. #3 Re: redused engine power
    Illionis
    Here are the codes:
    P1516-Command vs Actual throttle position performance, P1125-APP System(both are GM specific), P2125-Throttle/Pedal position sensor/switch E circuit, P2138-Throttle/Pedal position sensor/switch D/E voltage correlation, U0107-Lost communication with throttle actuator control module.
  4. #4 Re: redused engine power
    Those codes tell the whole problem.
    You have a Throttle body issue and a APP issue.
    I'd do some diggin and find out which one is the cause and replace as needed.
  5. #5 Re: redused engine power
    Apr 2012
    Middletown DE
    You could Google Ed Morad parts and see what they want for both.
    1993 Oldmobile 88
  6. #6 Re: redused engine power
    Yoga city
    uhm this happend last week to me, you have aftermarket intake by chance? i havent had to replace anything on my car yet its all been bad wires
  7. #7 Re: redused engine power
    Illionis
    yes i do have a K&N intake but i cant see that causing any problems
  8. #8 Re: redused engine power
    yup, it could be bad wires, the wires at the end of the plug that goes into the tps, take the plug off and inspect them for any cracks bare wire showing, or just missing insulation.
    the TB lives right over the exhaust cross over, the heat over time can beat the wire to death.
    if you find bad wires it easy enough to cut and solder a new pig tail on.
    if no bad wires i would start with a new tps sensor and go from there.
  9. #9 Re: redused engine power
    Illionis
    well here's the thing I work on semis and trailers i know what to look for when it comes to wiring problems external from the actual harness its self really its hard to say weather its the harness or not without preforming the proper test with a oscilloscope while the event is happening there is no real way to tell but ofcourse i could use a multimeter and measure the voltage out put and compare it to the voltage reference for that system, with that being said i would only do that test if i couldnt find a actual wiring problem
  10. #10 Re: redused engine power
    just look at them, no real need to go that far. if they are cracked at the end where the plug meets the wires or anywhere else, they get whats known as "dry wire". what happens is the wire turns brown, no longer nice and shinny, and the current does not pass correctly anymore.
    if you have wire loom over the wires take it off, stop at the main harness. and inspect those wires to the sensor. im thinking they are like 6 inches long or so from the main harness.
    my maf and ait sensors pig tails were so bad i had to cut them both 3 inches from the main harness, due to every time i would strip the wires they were still brown, it wasn't till i got close to the main harness that i got clean copper wire.
  11. #11 Re: redused engine power
    Illionis
    well i inspected the wires and found all to be good actually they look brand new. Then, i preformed a test with my oscilloscope and found that all is working well not voltage drops at all, so then i did some research and found that the throttle position sensor is inside the throttle body cover plate due to my gp having throttle by wire. Now ive located the problem which is: the potentiometer sensor or otherwise known as the throttle position sensor is getting abnormal or loosing all voltage. The soluation: replace the throttle body. To my knowledge i dont think they make rebuilds for that type of throttle body's.
  12. #12 Re: redused engine power
    Denver
    My GTO also has throttle by wire - reduced engine power can ALSO be a pedal potentiometer problem (not just on the TB end of things).
  13. #13 Re: redused engine power
    Illionis
    yes i agree but with the electrical system tests prove that it is the throttle body
  14. #14 Re: redused engine power
    Illionis
    I am such a dumbass. So i figured out what has been going on with it. The mass airflow sensor was very dirty and was not receiving or sending good readings. So i cleaned it up and now all is good she is back to normal so all of you out there experiencing the same problem i would suggest getting some mass airflow spray and cleaning up that sensor its a cheap and simple fix
  15. #15 Re: redused engine power
    Oct 2012
    Mississippi
    I had the same issue with my 04 grand prix and 06 impala. It turned out to be the electronic throttle body. Close to $500 for a new one
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. Engine Power
    By mongoclark in forum Engine
    Last Post: 01-18-2012, 12:52 PM
  3. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  4. Engine has no power
    By Midgethockey in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2009, 05:23 PM
  5. No engine power above 2-3K?
    By scottm in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2009, 02:58 AM
