Thread: L26 swap
Results 1 to 3 of 3
  1. #1 L26 swap
    Bettendorf, IA
    I'm in process of swapping out my old 3.4 DOHC motor to L26 swap in my 1995. I finally have it somewhat running. Using S/C TB, and 1.9 Yella Terra Rockers. It seems the engine is little more noisey than it was stock. Anyone have the rockers in and should I be caustious of the noise?
    I am also running the L36 injectors, are the L26 injectors better? Just wondering if I should wire these in?
  2. #2 Re: L26 swap
    Oil pressure gauge?
    I know the clatter is common on first start up...but it normally gets pretty quiet after a few seconds once it pumps up the oil.
  3. #3 Re: L26 swap
    Bettendorf, IA
    Oil pressure seems good. Almost seems like tic coming from the top of motor. Doesn't change after start up , cold or warm.
  1. l67 swap, trans swap
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2012, 07:11 AM
  2. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  3. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  4. Top swap help
    By uNda6gT in forum Northeast
    Last Post: 03-12-2010, 12:41 AM
