you could get speed daddy headers shipped for 200 ish, they come with a DP as well.
Headers are $200 cheaper then a plog :). Replace the flex pipe with a double walled because the single walled are known to give out. Get some band clamps from napa or frozenboost.com and enjoy the added flow mod. I won't go into to much detail about the speed daddy headers because there's a sticky with the info and can't link from phone right now.
I dont think you' ve even said what year make and model you have yet.
$200 speed daddys...install yourself or go to a muffler shop (either way you'll end up at the shop getting a cat welded on your new headers to clear the code unless you have an zftermarket or tuned pcm )..
OR
Just have a muffler shop replace the cat and grab yourself a couple o2s. No sense not replacing them if you're doing so much work. Plus I have a Rear o2 sitting around that I don't need if you want it.
Rockauto.com for the front cause parts stores will rape your pocket.
^ or you could just order online through advance and use a coupon code and get the part for about what rock auto charges and pick up that say and avoid for the most part shipping :)
Or that too. Whatever floats your boat my friend lol!
SD headers and use included race pipe (my band clamps got pulled apart so I had everything welded). New O2 sensors then never worry about that stupid cat again. You could get a new pcm for the car but you could just ride around with the check engine light on till you have the money for that.
Sent from my DROID RAZR using Xparent Red Tapatalk 2
