Those two large gauge wires. The one with just a loop is ground to trans stud. Teh other should usually have a red band on it, or there's a tab that sticks off the loop. That's the positive starter supply.
The two pin white connector. That's ABS wiring in the wheel well likely. If that connector were black..I'd call it magnasteer. but it's white/gray.
