Thread: Service engine soon light problem
Results 1 to 5 of 5
  1. #1 Service engine soon light problem
    Nov 2009
    California
    Fort the last year or so, the "service engine soon" light has come on. The first time, hooked the car up to a code reader. Spit out code: PO440. Purge valve(system) related. Replaced the valve solenoid located near the rear top of intake cover. Light did not come on for several months. The last month or so, it has come on and sometimes goes off by itself after a few days. Same diagnostic code. Is there some other element in the system that might be at fault? I have been regarding it as "the boy who cried wolf" syndrome. Is this a typical problem for a 100K plus milage engine? It's driving me crazy. Thanks in advance, Chumley
  2. #2 Re: Service engine soon light problem
    Start checking over all vaccum lines that relate to the evap system.
    Maybe even buy a new gas cap.
  3. #3 Re: Service engine soon light problem
    Nov 2009
    California
    Thanks, where is the charcoal canister located on 2001 Grand Prix? I think I'll start with the solenoid under the hood and work my way back.
  4. #4 Re: Service engine soon light problem
    Sep 2012
    Ottawa, Ontario
    The canister is near the driver's side back wheel. You can google a diagram to show you exactly where it is.
  5. #5 Re: Service engine soon light problem
    Apr 2011
    Elk Rapids, Michigan
    Check your gas cap. I've had an EVAP code caused by a loose cap. I don't remember if it was that code but it's something easy to check. Also check the o-ring on the gas cap, they can crack and cause a vacuum leak.
  1. Service engine light
    By buck in forum General Tech Discussion
    Last Post: 06-05-2012, 11:01 PM
  2. Service engine light
    By s33dl3ss in forum General Tech Discussion
    Last Post: 07-30-2011, 04:10 PM
  3. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  4. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  5. Service engine soon light
    By the955iman in forum General Tech Discussion
    Last Post: 02-15-2009, 01:21 PM
