Thread: maybe injectors?
Results 1 to 13 of 13
  1. #1 maybe injectors?
    Sep 2012
    fort Wayne, in
    So I've beg trying to figure this out for awhile now.i have a99gt when I'm driving the car bogs down when under acceleration light or heavy.sometimes it has no hesitation our anything like that it gets up and goes no problem but sometimes higher rpms it sputters. I know I have an exhaust leak but doubt this could do wheats going on. How can I trouble shoot if injectors are bad? Don't have a voltage meter, but what all could do this? I've changed the coils, ignition control and wires, fuel filter please I need some help
  2. #2 Re: maybe injectors?
    Ohio
    metal sleeves around the wires still??
    maf?
  3. #3 Re: maybe injectors?
    Sep 2012
    fort Wayne, in
    What you mean metal sleeves on wires? I havnt checked the maf yet but maybe fine cleaner would work? It also sometimes surges into the next gear or hesitates at higher rpms but don't think it is the ttanny
    Ohio
    The boot protectors where the wire attaches to the plug.
  5. #5 Re: maybe injectors?
    Sep 2012
    fort Wayne, in
    Last time I checked they were there with maybe very little to no movement in the wires, I Have to get the tip that has the button in the middle of the maf to get that cleaned, but what would a dirt maf sensor cause
  6. #6 Re: maybe injectors?
    Dat exhaust leak.. is she before or after the o2 sensors? Cuz that'll do it. So will a clogged cat.
    I can tell yuh, dis is not 6 injecteers failin all at the same time.
    Ohio
    I'm saying if the metal sleeves are there..take them off.
    And bill im glad you noticed the exhaust leak statement.. so x2 on what bill said. Where is it leaking?
  8. #8 Re: maybe injectors?
    Sep 2012
    fort Wayne, in
    i havnt gotten the exhaust leak checked out yet. ive looked underneath but i see any holes. i can take it to a exhaust shop and have them check it out right? anyone know of rates just for checkin or even welding them shut?
  9. #9 Re: maybe injectors?
    gardner,mass
    Quote Originally Posted by 99pgpgt View Post
    Why take off the metal sleeves around the plugs?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  10. #10 Re: maybe injectors?
    Some people get misfires from them.
    I never did, but I took them off anyway.
    Ohio
    They are kind of a last resort thing.. But it's good to do it early so that's out of the way.
  12. #12 Re: maybe injectors?
    Sep 2012
    fort Wayne, in
    ok so i pulled the plugs cleaned them off and put them back because they seemed like they were fine and also checked the gap and they were fine, when i put them back in and started the car, i noticed a slight noise, i wouldnt say knock, maybe a rattle? but something moving around the top of the engine when i put some gas to it, i had the hood open so i could hear it. but the guy before me that had this car said he swapped out the wires which i know he did and he put in autolight platinums?? should i get different ones?
  13. #13 Re: maybe injectors?
    Sep 2012
    fort Wayne, in
    ok so i had it scanned at autozone and it said an o2 sensor was bad, the code came up twice is what this guy said. the exhaust does have a more distint noise. so he said it was the one by the passanger side? im guessing he is refering to the one right behind the u-bend right? do i need a special tool to undo the sensor or can i just get a wrench in there and get it out?
  1. Injectors
    By ray4was in forum General Tech Discussion
    Last Post: 05-27-2011, 06:13 AM
  2. Injectors
    By jdwyat in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-27-2010, 01:00 PM
