Thread: Top Swap progress
Results 1 to 20 of 21
  1. #1 Top Swap progress
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    Im getting all may parts together for my up coming top swap on my 01 Grand Prix Gt. So far i have the supercharger, fuel rails, and the tensioner and idler pulleys. I know i still need the LIM, heads, valve covers injectors, and the harmonic balancer but am i missing anything else? Also when i start the swap will i have to splice wires or engine harnesses? I heard something about injector connectors will i need those.
  2. #2 Re: Top Swap progress
    Maybe?
    I'm 100% sure there is this info in many threads.
  3. #3 Re: Top Swap progress
    Dec 2011
    Decatur
    Are these the only wires i would need to splice? L36 to L67 Wiring Conversion Kit
  4. #4 Re: Top Swap progress
    I have some of the parts you need if you're interested.
  5. #5 Re: Top Swap progress
    Grand Island, Nebraska
    You will need injector connectors, yes. You don't have to worry about the BBV harness if you leave the bottom nipple open. The screws from the coil pack don't fit in he new bracket, so make sure you have the right screws or a tap.
  6. #6 Re: Top Swap progress
    Dec 2011
    Decatur
    I can just take the screws out off of a gtp coil pack right? And how do i install the extra pulleys? And is that safe to leave it open?
  7. #7 Re: Top Swap progress
    Florida
    Quote Originally Posted by 01GrandPrixTURBOGT View Post
    missing:
    L67 coil bracket
    l67 tb
    you will not need different injector connectors to go from l36 to l67 injectors. if you are going to run a l36 pcm file tuned for the sc then you may still beable to use your current map. but most swap to a l67 and need to change the connector. i have heard some swap to the newer series 3 map and are able to use the current map connector. like said no need to run the bbv soloenoide. also i would suggest addressing the fuel lines during the swap. i have heard many have leaks when trying to get l36 lines to work on their l67. i am just going to swap to AN lines. $100 or so in parts is worth not having to worry about a car fire.
  8. #8 Re: Top Swap progress
    Dec 2011
    Decatur
    Quote Originally Posted by Z34Phoenix View Post
    missing:
    L67 coil bracket
    l67 tb
    What all would i need to run those AN lines?
    You have to use the map sensor for the base file you use unless you change the map settings via tt.
  10. #10 Re: Top Swap progress
    Yes my lines leak a little. And the bbv will end up being vacuum operated instead of controlled by the PCM. Search bro
    My lines on leaked when they needed a new o ring. Replaced the entire connector and its been fine.
  12. #12 Re: Top Swap progress
    Dec 2011
    Decatur
    I forgot to mention i have a TB. Im keeping the l36 pcm. And how do i put these pulleys on ive been looking and it doesn't make sense.
  13. #13 Re: Top Swap progress
    the 3" on the stand bolts to the block.
    The ribbed one goes on the front most position of the cast iron engine mount bracket
    The tensioner (flat 2.5") gets mounted on bracket closer to the charger
    FWIW if you
  14. #14 Re: Top Swap progress
    Dec 2011
    Decatur
    thats were i messed up i only have the pulleys themselves. i gotta get the pieces they go on to still
  15. #15 Re: Top Swap progress
    Dec 2011
    Decatur
    When removing the idler pulley on the L67 should coolant leak out of the block? Im just making sure im removing the right bolts.
  16. #16 Re: Top Swap progress
    Pennsylvania, USA
    I believe coolant flows through the idler pulley on all 3800 series II motors, the coolant elbows which have a knack for disintegrating upon removal are located there right? They were on my L26, both snapped on both ends when I pulled my idler off, along with a bunch of coolant flowing out everywhere :P
    Pick up some coolant elbows now if you don't have any or you've never replaced them, because they will probably break.
  17. #17 Re: Top Swap progress
    Dec 2011
    Decatur
    Sorry I meant the idler pulley for the supercharger. The one closest to the harmonic balancer.
  18. #18 Re: Top Swap progress
    Dec 2011
    Decatur
    Bump?
  19. #19 Re: Top Swap progress
    Click the search button at the top and search on braided lines and my screen name. That should get you set on that front.
    What are your other questions? I can't read the whole thread at the moment.
  20. #20 Re: Top Swap progress
    Dec 2011
    Decatur
    Im wonder if the supercharger idler pulley closest to the harmonic balancer if when removing the bolts coolant should flow out of the holes? Im asking cause i started to loose one bolt that i thought was the right one coolant came out.
  1. [10-09-2013 ] 3800 swap&topswap Complete!
    By Z34Phoenix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-09-2013, 01:55 PM
  2. GTP in Progress
    By eshina17 in forum Members Rides
    Last Post: 07-14-2013, 08:38 PM
  3. my progress
    By Peacher213 in forum Members Rides
    Last Post: 03-07-2012, 11:49 PM
  4. Pics of my swap progress
    By NineD9GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2010, 02:44 PM
  5. Progress on my 97 GTP
    By shawn3091 in forum Visual/Body Modifications
    Last Post: 11-05-2009, 06:36 PM
