Thread: Hard cranking with new battery?
Results 1 to 20 of 26
  1. #1 Hard cranking with new battery?
    Aug 2012
    United States
    Hi guys!
    Just put a new battery in my car and now its cranking hard...I've never had this problem before... A a couple of days ago I drove through some pretty big puddles (small rivers!) I have a '98 GT...Never had a problem, suddenly the battery is shot and this hard starting. The guy a Advanced tested everything when he put the new battery in and said the starter and alt. were doing there jobs. Just a side note on the way home the a/c started blowing hot on the passenger side only. Should I be worried about electrical problems?
  2. #2 Re: Hard cranking with new battery?
    St. Louis
    Have you cleaned the battery terminals and the wires at the starter? Almost sounds like a dirty/bad ground somewhere.
    On the hot air from the pass. side sounds like a blend door actuator. This is mounted on the passenger side of the airbox. IIRC you have to remove the glovebox and you can see/remove it from there.
  3. #3 Re: Hard cranking with new battery?
    Aug 2012
    United States
    Just to clarify the A/C is blowing cold on drivers side and hot on passenger at the same time... pass duel control is at lowest temp. Should I still be checking the door actuator? As to battery terminals, yes cleaned. Will have to check starter wires.
    Thanks for the info
    Sharon
  4. #4 Re: Hard cranking with new battery?
    Aug 2012
    United States
    Just to clarify the A/C is blowing cold on drivers side and hot on passenger at the same time... pass duel control is at lowest temp. Should I still be checking the door actuator? As to battery terminals, yes cleaned. Will have to check starter wires. Oh what does IIRC mean?
    Thanks for the info
    Sharon
  5. #5 Re: Hard cranking with new battery?
    St. Louis
    IIRC= If I recall correctly.
    What happens if you move the pass. side climate control to hot? Do you hear clicking?
  6. #6 Re: Hard cranking with new battery?
    GTX Level Member cerick08GP's Avatar
    Iirc = if I recall correctly
    If the hard starting turns into no starting, the first thing I would check is the in-line fuse. Good luck
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  7. #7 Re: Hard cranking with new battery?
    Aug 2012
    United States
    Quote Originally Posted by FordMan77 View Post
    No clicking, just the same hot air, like the highest heat setting.
    Thanks for the info on IIRC
  8. #8 Re: Hard cranking with new battery?
    Jul 2012
    Chicago
    Could the hot air on the passenger side signify a low system charge? (Freon)
    -Carl
  9. #9 Re: Hard cranking with new battery?
    Usually when the system is low the drivers side is hot passenger side cold.
  10. #10 Re: Hard cranking with new battery?
    Aug 2012
    United States
    I'm pretty sure it has to do with the battery being replaced
  11. #11 Re: Hard cranking with new battery?
    sometimes when you take the battery off the blend door actuators get confused. try taking the battery off for 20 minutes or so, hook it back up turn the key to run hit auto on the climate control, with any luck it will fix its self, if you listen closly some times you can hear then turning back and fourth.
    worst comes to worst you need a new actuator from the pass side, you can also take it off and just turn the small knob to cold till you get a new one.
    heres the how to, to get to them. http://www.grandprixforums.net/blend...ent-21941.html pass side is real easy. to get to.
  12. #12 Re: Hard cranking with new battery?
    Aug 2012
    United States
    Thanks for the info, I've tried taking the positive cable off for 1/2 hr, that didn't work, then left the neg off over night, that didn't work. One guy said it make 2-3 times with positive off and on. I guess I'll try that before I attempt the door!!! Been awhile since I tore a dash apart! lol I know its not the dash, but close enough!
  13. #13 Re: Hard cranking with new battery?
    all you need to do is take the glove box out, take the foot cover, insulator off, should be 3 push tree sty pins. pull them out drop that cover, then take 4 small bolts out, looks like a piano hinge, then open and remove the glove box, that easy. the actuator look to the left side in the glove box hole.
  14. #14 Re: Hard cranking with new battery?
    Aug 2012
    United States
    Sounds like fun!! teehee not really, but you have made it sound easy - thanks I'll keep you updated on my progress
  15. #15 Re: Hard cranking with new battery?
    Aug 2012
    United States
    So the battery cable disconnection hasn't done the trick 30, 15 30 no go. So I'm looking at the door..it was open to start off with, I pulled it shut and the air is still hot, so your saying to remove it completely and turn what small knob? for the cold air, till I can replace it? Will look at directions on removal again and go attempt that. Should the battery be disconnected for any of this?
  16. #16 Re: Hard cranking with new battery?
    this is the glove box side, the black box thats not attatched is the actuator, follow the line thats the little knob you need to turn.
    1. Remove the right instrument panel insulator. (The carpeted cardboard piece below the glovebox)
    2. Remove the instrument panel compartment. (glovebox)
    3. Disconnect the electrical connector from the temperature actuator.
    4. Remove the HVAC Con (HVAC Control) MiniFuse #27 from the IP electrical center.
    5. Remove the bolts retaining the temperature actuator.
    6. Remove the temperature actuator.
  17. #17 Re: Hard cranking with new battery?
    Aug 2012
    United States
    Do you know if the door should be open or closed? It doesn't seem to matter
    Maybe it's not the actuator? I'm soooo looking for some success!
  18. #18 Re: Hard cranking with new battery?
    off hand i dont recall witch way is hot or cold, but if you turn the a/c on high, wait for it to get cold, turn the knob, turn it one way if hot air comes out, turn it the other way, cold should come out.
    it only moves a small amount, you can feel a door shut when you turn it.
  19. #19 Re: Hard cranking with new battery?
    Aug 2012
    United States
    So it's not that big door right in front of my eyes? There's another door somewhere...very interesting
  20. #20 Re: Hard cranking with new battery?
    no thats not it. thats the recirculate door. lets fresh air in. look to your left, use a flash light in broad day light it helps, its dark in there.
    the black box thing you see not hooked up to anything, with the line to the hvac part in this pic. follow the line, that the little knob, its white. take the actuator off and turn the knob.
    this is what the part looks like. the large round hole sits over the little knob
  1. Starter hangs in.Keeps cranking after key released
    By Smallblock in forum General Tech Discussion
    Last Post: 03-09-2012, 06:59 AM
  2. Amp to Battery
    By SE2001 in forum Audio, Security & Visual Electronics
    Last Post: 02-11-2012, 02:33 PM
  3. Slow labored cranking
    By pc305577 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2009, 07:58 AM
  4. '98 SE L36, no fuel pressure while cranking
    By 98SEGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-13-2009, 01:56 AM
  5. okay, I took the battery out of my '96 GP
    By karkev in forum General Tech Discussion
    Last Post: 06-17-2009, 09:21 PM
