Thread: White smoke from underhood. Help!
Results 1 to 9 of 9
  1. #1 White smoke from underhood. Help!
    Jul 2012
    i have a 2000 gt 3.8L not supercharged.
    Wife gets home today and White smoke is coming from under the hood checked the inside car it not reading hot no lights are on. i thought maybe something on the hud might nto be working so i decided to try and add water to the coolant anyways. i opened up the coolant tank and could add maybe less than a half gallon didn't seem to be missing much. i know i do have a small leak on an elbow that was brought to my attention but it was nothing major at the time and i am tight on cash i decided to wait on it. could that leak be causing the white smoke now? also i had plugs and cables changed today not sure if that could possibly contribute to this.
    one more thing i was told there is a recall on my car i'm not sure for what does anyone have any info on this?
  2. #2 Re: White smoke from underhood. Help!
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    the recall is for leaky front valve cover gaskets. under hard braking, they can spill out oil onto the exhaust manifold, and the oil will smoke and it smells pretty bad. did it smell like coolant?? or something much worse?? cause oil has a very distinct smell when it burns haha. and back too the point... have this issue addressed immediatly, because oil can ignite and cause a nasty engine fire.
  3. #3 Re: White smoke from underhood. Help!
    Jul 2012
    well wife was driving it i turned it on now and nothing happened idk. she says shes not sure what coolant smells like but it didn't smell like oil and the smoke was white.
  4. #4 Re: White smoke from underhood. Help!
    Likely coolant from that elbow. Want to fix it for about an hours work and $4? We can tell you how.
  5. #5 Re: White smoke from underhood. Help!
    Jul 2012
    yeah of course if its something i can get done at home easy im up for it reason i didn't do it before was because a franchise mechanic shop told me it would cast about 120$ to get it fixed.
  6. #6 Re: White smoke from underhood. Help!
    May 2012
    pensalvania
    120$ isn't really that bad of a deal for it. but it is something very easy too do yourself if you have a good guide.
  7. #7 Re: White smoke from underhood. Help!
    Here's the how to. The elbows should be about $4 at the parts store. Dorman # 47065
    http://www.grandprixforums.net/how-c...ows-49779.html
  8. #8 Re: White smoke from underhood. Help!
    I live here. TLSheff's Avatar
    We should sticky that "how to" of yours Bill... link fail?
  9. #9 Re: White smoke from underhood. Help!
    too much multitasking
  1. New here need help please!!!! On white smoke
    By crazybrownklick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2011, 02:37 PM
  2. white smoke :'(
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2011, 10:50 PM
  3. white smoke.
    By gtpinsc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-17-2011, 12:08 PM
  4. White smoke
    By dhaller in forum General Tech Discussion
    Last Post: 04-14-2010, 08:13 PM
  5. White smoke
    Last Post: 04-10-2010, 06:29 PM
