Thread: top swap help
Results 1 to 12 of 12
  1. #1 top swap help
    Dec 2011
    baltimore
    ive almost have everything i need for a top swap just missing harmonic balancer, injectors, pcm, and mps... but i want to cam it with the xp cam from zzp besides the cam what else would i need to install it? im trying to get a list together so i know what i have to save up, thanks in advance
  2. #2 Re: top swap help
    Grand Island, Nebraska
    Headers, something to scan with (preferably a tuner) you need valve springs and the zzp valve seals that give more clearance.
  3. #3 Re: top swap help
    Mar 2012
    NC
    ZZP has a cam install kit too...it's nice.
  4. #4 Re: top swap help
    Yeah...if you like gaskets that don't fit or leak.
  5. #5 Re: top swap help
    Dec 2011
    baltimore
    thanks any write ups on here on how to actually install the cam? im trying to learn
  6. #6 Re: top swap help
    You doing it in or out of the car?
  7. #7 Re: top swap help
    Dec 2011
    baltimore
    sry for the late response but yes im doing it in the car
  8. #8 Re: top swap help
    biggest tip I can give you is put the car on jackstands to bring your work surface up a little. That'll save your back.
    Other than that.. once you pull one of the lower corner head bolts..use a tube to pull coolant out of the bolt hole. That will keep you from filling your cylinders etc.
  9. #9 Re: top swap help
    Dec 2011
    baltimore
    ok well all the coolant will be outa the car because im top swapping, so im doing everything at once, but thanks im trying to achieve around 280-300whp any advice on a build? im kinda new to this so im looking for as much help as i can
  10. #10 Re: top swap help
    you'll need a cam or rockers and intercooler.
    headers are a given as well.
    as are 42.5 injectors.
  11. #11 Re: top swap help
    SE Level Member rell2005's Avatar
    Detroit / Grand Rapids
    I did my Top Swap and added a full size IC in April....My best advice is make sure you have atleast $200-$300 extra for little stuff you'll come across. I actually forgot to get valve covers but I lucked up and a buddy gave me some. And make sure the impact is strong enough to take the Crank Bolt off...Mines wouldn't even make the bolt budge. so I had to go to a friends shop and use theirs. Came off effortlessly. Good luck
    Top-Swapped GT, SLP headers, 3.2 Pulley, Stage 2 Intercooler
  12. #12 Re: top swap help
    Dec 2011
    baltimore
    thanks, yea i have a check list and im making sure i have everything before the build starts
  1. l67 swap, trans swap
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2012, 07:11 AM
  2. Top swap
    By 443pearl in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-05-2012, 12:10 AM
  3. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  4. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
