Thread: N* install and plug question
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 73
  1. #1 N* install and plug question
    GT Level Member deadsnake's Avatar
    Round lake, IL
    Hey there guys I had a few questions regarding some installs.
    I purchased a ZZP N* kit w/LQ4 MAF set up for when I do my top swap but my question is.... can I install this set up even before the top swap and run is at is for now or no?
    Also I am looking to change the plugs out, they need to be replaced, what should I go with and what kind of gapping?
    As it sits now its a 98 GT with pace setter headers, full exhaust and GT1 cam.
    Thanks!
  2. #2 Re: N* install and plug question
    Maybe
    Really depends on what adapater plate you got. You didn't mention it or which charger...so dat's about the bestest answer we can give you.
  3. #3 Re: N* install and plug question
    Round lake, IL
    Its going to be a Gen v install
  4. #4 Re: N* install and plug question
    Nope..you can't.
    Reason being is your TB adapter will have 4 hole square pattern for the Gen V or L26 intake. Being that you have a 98, you're intake manifold will have a 3 hole triangle pattern.
  5. #5 Re: N* install and plug question
    Round lake, IL
    this is the adapter plate... and what about the plugs?
  6. #6 Re: N* install and plug question
    You didn't get the adapters for the wiring?
  7. #7 Re: N* install and plug question
    Round lake, IL
    Yes I did
  8. #8 Re: N* install and plug question
    Then I'm confused what you mean by "what about the plugs". If you got the adapters, then you simply plug them in.
  9. #9 Re: N* install and plug question
    Round lake, IL
    Spark plugs sorry lol
  10. #10 Re: N* install and plug question
    Start with Autolite 104's, gap them at .050"
  11. #11 Re: N* install and plug question
    Would you give us a few details.
    Do you want plugs for your current setup or future? What does your top swap consist of, Gen V and what else?
  12. #12 Re: N* install and plug question
    Round lake, IL
    Plugs for now till I do he swap. Gen v zzp stage 3 ic built heads n*tb xp cam etc
  13. #13 Re: N* install and plug question
    I'd suggest copper core stock replacements. That way it's cheap. You won't be able to reuse them later.
  14. #14 Re: N* install and plug question
    Round lake, IL
    I don't care about cost
  15. #15 Re: N* install and plug question
    Cool...then replace with stock iridiums from AC Delco
  16. #16 Re: N* install and plug question
    But do not run those plugs on the build...way too hot.
  17. #17 Re: N* install and plug question
    Round lake, IL
    Okay sounds good thanks, also so typically all i would need to run this tb set up is another adapter plate right?
  18. #18 Re: N* install and plug question
    Minnesota
    Gonna want a tune too
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  19. #19 Re: N* install and plug question
    Apr 2011
    Tally, FL
    did u make that adapter yourself? that allows a N* to bolt up to a l36 uim?
  20. #20 Re: N* install and plug question
    No DB he didn't. That's a L36/L67 TB to Gen V/L26 UIM adapter in the pic.
  1. PCM and spark plug question
    By jjwalton77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2011, 05:31 PM
  2. plug question
    By clevelandfan in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-02-2010, 07:47 AM
  3. Spark plug install
    By 04CompG in forum General Tech Discussion
    Last Post: 09-28-2008, 10:15 AM
  4. Spark plug question
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2008, 05:36 PM
