Thread: Intake manifold leaking coolant?
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
  1. #1 Re: Intake manifold leaking coolant?
    Jul 2011
    Houston
    Alright, I got the parts today, went felpro on everything. Hopefully I'll get started on it today and finish tomorrow. I'll let y'all know how it goes
  2. #2 Re: Intake manifold leaking coolant?
    SE Level Member 99XC600's Avatar
    Apr 2012
    Wilbraham MA
    Take your time and don't be a gorilla when taking everything apart. Be methodical and patient and it will come apart fairly easily. Just did mine 2 weeks ago and honestly it wasn't that bad.
    2004 Ivory White Pontiac Grand Prix GT1 - Bone Stock and my 80 mile daily driver.
  3. #3 Re: Intake manifold leaking coolant?
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    oh, very important note, make sure you use an inch torque wrench on the bolts, and use the correct weight/sequence. the uim's are very easy to crack and ruin by using to much force.
  4. #4 Re: Intake manifold leaking coolant?
    Actually..when you are torquing the UIM... watch the plastic around the bolt. If it starts turning white..that bolt is tight enough.
  5. #5 Re: Intake manifold leaking coolant?
    Jul 2011
    Houston
    After opening up the intake I saw a lot of oil in there...
    And that is after I had soaked some of it up. Is that normal?
  6. #6 Re: Intake manifold leaking coolant?
    Apr 2012
    Wilbraham MA
    Yes, mine had the same thing. Just remember that beneath those 2 puddles of oil are the last 2 bolts holding down the intake. Vacuum the oil out with a shop vac or something and you will see the bolts.
  7. #7 Re: Intake manifold leaking coolant?
    May 2012
    pensalvania
    yes thats normal...at least when the uim was bad lol. just make sure u clean as much of it out as you possibly can. and clean the gasket surface real well.
  8. #8 Re: Intake manifold leaking coolant?
    Quote Originally Posted by bmx6454 View Post
    Sorry guy.. it's normal for a good running motor without a bad UIM. When the UIM is bad the LIM fills with coolant, not oil. Oil is normal because the PCV dumps into the UIM/LIM via the tube in the UIM that is held in by the gasket frame. This allows oil vapor etc which contains enough oil over time to puddle.
  9. #9 Re: Intake manifold leaking coolant?
    If this hasnt been said already, when you are finished, please drain the oil and run new oil in it and then change it again after 10 min of running with a new filter to insure you got any coolant out.
  10. #10 Re: Intake manifold leaking coolant?
    Jul 2011
    Houston
    Thanks all! Finished putting replacing all the gaskets and putting everything back together. Hit a few bumps along the way but finally finished! Now to monitor coolant levels and change the oil...
  11. #11 Re: Intake manifold leaking coolant?
    May 2012
    pensalvania
    congrats. make sure you bleed all that air out of the coolant as well. and a good thing i like to do is put a little sea foam in the oil and run it for about 10-30 minutres before i change the oil. it seems to really help get all the gunk out of there. but dont leave the seafoam in for long as it can be harmful to leave in too long.
  12. #12 Re: Intake manifold leaking coolant?
    May 2012
    pensalvania
    really?? i thought that any fluid in there was bad... well i learned something new then haha
  13. #13 Re: Intake manifold leaking coolant?
    Because the PCV vents into teh manifold, you will end up with some oil in the vapor. This is why on some other platforms you'll see guys putting on an oil catch can. That can keeps the oil from going back into the intake.
  1. lower intake manifold might be leaking...
    By andremike in forum General Tech Discussion
    Last Post: 07-24-2012, 11:00 AM
  2. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  3. Leaking intake manifold gasket
    By egloskerry in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-03-2011, 01:58 AM
  4. 136,000 miles, losing coolant, intake manifold gaskets shot from DEX COOL ???????
    By Skillet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2011, 10:51 PM
  5. leaking intake manifold
    By chrizzle17 in forum General Tech Discussion
    Last Post: 01-09-2009, 11:30 AM
